I'm looking to buy a prebuilt Dell XPS refurb. I will be buying off ebay so prices will be as listed - ~30%. Which system gives the best CPU/GPU combination for the best price? Consider the possibility that I might overclock, but nothing extreme.. novice stuff.
$1600
$1550
$1500
$1350 +$75 = $1425
$1300
$1250
$1150
$1100
# Intel Core 2 Quad Q9550 2.83 Ghz 1333 Mhz FSB 12 mb cache CPU 45nm Technology
# 4 GB Memory ( 800 Mhz)
# 1 x 80 GB 7200rpm SATA Hard Drive
# 1 x 1000 GB 7200rpm SATA Hard Drive
# 20X DVD Writer +/- R/R/W dual layer writer
# 1.44MB Floppy Drive
# ATI 4870x2 Video Card with 2048mb memory and Dual DVI outputs
(Card is 2 4870 cards with Cross Fire in one package)
# Onboard Audio
# Onboard Gigabit Ethernet 10/100/1000 network controller
$1600
# Nvidia Geforce GTX 280 with 1024 MB memory, Dual DVI outputs
# Onboard Audio
$1550
# Onboard Audio
$1500
Chassis/Motherboard: Mini Tower chassis. Motherboard based on Intel® X38 chipset, 525 Watt Dell Power Supply
Processor: Intel Core 2 Quad Q6700 2.66GHz @ 3.33GHz (8MB L2 Cache & 1333 MHz FSB, 100% Stable)
Video Card: Asus 9800GT 512MB Video Card (Overclocked) - Dual DVI, TV-Output (Factory overclocked to 725MHz Core / 1750MHz Shader / 2000MHz Memory)
Memory: 4GB Corsair XMS PC2-6400 / DDR2-800 Dual channel Memory (4 DIMM's...4 x 1GB)
Operating System: Windows Vista Premium (32bit), Install Disc Included
Hard Drive: Western Digital 640GB 7200RPM SATAII Hard Drive (Model# WD6400AAKS)
CD / DVD Burner: 16X DVD Bunrer
Sound Card: Integrated 7.1 Channel High Definition Audio
Network Card: Integrated 10/100/1000 Gigabit Ethernet Controller
Likely add: Upgrade from 640GB Hard Drive to Seagate 1TB SATAII Hard Drive (7200.11 Series).....Add $75
$1350 +$75 = $1425
# Nvidia Geforce 8800GT with 1024 MB memory, Dual DVI outputs
$1300
Intel Core 2 Quad Q9450 2.66GHz 12MB
4GB DDR2 800MHz RAM Memory
250GB 7200RPM SATA II Hard Drives
16X DVD+/-R/RW Dual Layer Burner
1024MB Nvidia GeForce GTX 280
$1250
Intel Core2 processorQ9450 (2.660GHz,1333FSB) w/Quad Core Technology and 12MB cache
4GB DDR2 SDRAM at 800MHz
Nvidia GeForce 9800GT Dual Scalable Link Interface
640GB SATA Hard Drive (7200RPM) w/ DataBurst Cache
$1150
Intel Core 2 Quad Q9550 2.83GHz
3GB DDR2 800MHz RAM Memory
500GB 7200RPM SATA II Hard Drives
512MB ATI Radeon HD 3870
$1100
