- Jul 16, 2000
Which nForce driver set should I use with my NF7-S? Do I want to install all the drivers in the package? I assume they are like the VIA Hyperions..
comicbob said:Just use the latest drivers.
Not exactly. The latest, 4.24 version of the nForce driver kit no longer includes the "IDE-In-The-Box" drivers. And the default Microsoft Windows XP-provided driver doesn't work correctly on the nForce2 chipset unless it was tweaked by nVidia itself - notice the roughly 80% CPU utilization even with Ultra DMA enabled - since it doesn't support Ultra DMA Mode 6 at all. (At such a high CPU utilization rate, you might as well cripple your IDE devices by capping their transfer rate at 16.6 MB/s using PIO only.) That can cause serious problems with timings. As a result, you're forced to install the SW driver in order to keep the CPU utilization under check.comicbob said:Just use the latest drivers.
The "IDE-In-The-Box" drivers are just Microsoft IDE drivers that have been tweaked to work correctly on nForce IDE controllers. The 4.24 kit no longer includes those drivers - so you'll either have to install the nVidia SW drivers (which caused problems with my CD drives) or be stuck with the non-optimized default Microsoft IDE drivers (which don't support Ultra DMA 6, and causes drastically increased CPU utilization).marka211 said:The 4.24 drivers support Ultra DMA 6 and come with the driver kit, along with updated drivers for sound, Gart, memory controllers, and nvidia's ethernet port, plus when you go into the device manager and open up the ATA controller, you can run a speed test on your HD's.
The newer 4.27 mainly just updates the sound drivers and tweaks the HD controller drivers for better performance and compatiabity.
By the way E4g1e, what do you mean when you say no IDE-In-The-Box drivers, when I installed the 4.24 drivers, it asked if I wanted to install the Nvidia Ide drivers, said yes, and have experienced better performance, reduced loading time for games and windows boot times, with no compatiabity problems.![]()
E4g1e said:The "IDE-In-The-Box" drivers are just Microsoft IDE drivers that have been tweaked to work correctly on nForce IDE controllers. The 4.24 kit no longer includes those drivers - so you'll either have to install the nVidia SW drivers (which caused problems with my CD drives) or be stuck with the non-optimized default Microsoft IDE drivers (which don't support Ultra DMA 6, and causes drastically increased CPU utilization).
I'd say that the default Microsoft drivers don't support the nForce2 chipset correctly. If you don't want to install the SW IDE driver, I'd strongly advise you to revert to an older driver version, since the two most recent nForce driver releases no longer include the IDE-In-The-Box drivers. I've tried the default Microsoft drivers, only to find out that the read CPU utilization had shot up all the way to 85% on an ATA/100 drive (even though I made sure that Ultra DMA was enabled in Windows). With that level of CPU utilization, you might as well run all of your PATA drives in PIO-only mode, and cap their maximum burst transfer rates at 16.6 or even 11.1 MB/s. Therefore, I'd only recommend the two most recent nForce driver releases if you're going to either use the SW IDE driver or run a special version of Windows that already has the correctly optimized IDE driver (not out yet, unfortunately).PimpBot5000 said:Latest ones are the boss. Tey have improved alot. But I still do not recommend the SW IDE driver, as it causes too many damn problems.
