one30eight
- Sep 16, 2004
I have been using G.Skill for a while now and have been happy with it. I am replacing 4 1 gig sticks with 2 2 gig sticks and have been looking at a lot of memory. It will be going into a DFI LT board with an e6550, which only has the 7x multi. I have always gone with the G.Skill because I believe you get a lot for the money. However, I have been thinking I want to try something new. So, in the 50ish price range, what is best to pair with that e6550? One thing that does matter is the heat spreaders. I need black. Thanks!
I was looking at these
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227420
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231192
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227267&Tpk=ocz reaper 800
Decided to go with these
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227419
