Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
What kind of system? A64 or P4? Lower latencies tend to OC better because there is more room to "loosen" the timings and run the RAM faster. Ideally, lower latencies coupled with higher speeds is your best combo.
In simple terms, the higher the latency/timings, the slower the RAM communicates because of the timed delays between read and writes. (But maybe I'm way off and someone can explain it better ).
I'd so love to run my memory 1:1 on my Venice...I just don't think it's ready to run at 2.7GHz yet.
Lower latencies are always better. On P4 latency is less significant because the architecture's going to screw it up for everyone anyway, so clock speed means everything. On A64, the speed you can overclock your memory to means jack shit, and latency is everything.
