What To Do?
theseeker
I am not sure if this the best place to start this thread, but I need some advice.
I am about to do a complete upgrade or a complete rebuild. I would appreciate any comments, opinions or any suggestions you have.
My current system is in my sig.
I am considering three options:
1. Keep my basic system and upgrade my CPU's (2 256's or 2 285's) Total Cost-$1,140
2. Change the MB and the CPU's ( 2 FX-74'S) which means I will have to buy new RAM-Total cost $2690
3. Go to the dark side and go with intel 1 E6600, eVGA 680 SLI MB and 4Gb of Corsair Dominator RAM-Total Cost $1310
Money is not an issue. I am just looking for the biggest bang for the buck and hopefully something that will be future proof for at least 2 years.
Once again, I would appreciate any input.
Just an FYI if you do go for the C2D, the 6600 and evga 680i-A1 (newest revision that fixes quad core) have a $39 instant rebate as a combo deal. Also has Supreme Commander for free.
Just picked it up myself :)
Also leaves the road open to quads when they drop in price in the next few months.
The quad has little or no value to me as there are no games that take advantage of it. Having said that, I would truly appreciate some feedback on what to do regarding the system.
3.
( I know, it hurts)
FYI:
with a 6600 you are pretty much wasting money on ram that is rated faster than pc6400(800MHz) (9x400 = 3.6GHz which is close to the upper 6600 OC limit in most situations) unless you water cool or other extream OCing. Tight timings are good, quality manuf good, but you dont need high speed and you want to run the memory synch with FSB.
Then why are you looking at getting a 2xFX 74 system or a 2x285 system if quad core has little or no value to you :confused: ? If you're going to go that route, you might as well get a 680i and QX6700.
