I don't use a mouse at all.
I use a Logitech Trackman Optical Wheel Trackball.
Works excellent in every game I've played, especially 1st Person Shooters.
It doesn't strain/cramp my wrist & I'll never use anything else...![]()
Low sensitivity = more accuracy.
I used a Microsoft Intellimouse Explorer 3.0 until it died a few months ago. I got nearly 6 years of use out it and it served me well. I hear the new ones suck, so I replaced it with a Logitech MX518 and couldn't be happier. It's much more accurate and tracks smoother.
That's...2 buttons and a scroll wheel? Not going to work too hot for MMO-type PvP such as WoW, CoH/V, WAR, etc.
I actually like trackballs too, but I gave them up when I started PvPing in anything more serious than Diablo II.
-S
Help a staph infected drugged up brother out.
Where's the offset to the low sensitivity? If your crosshairs move along the screen at half the speed as mind, there's no way you can live.
I've had my MX1000 for like three years and I do love it but for two exceptions... A) It's gotten pretty gunky around the sides on the rubber surface, bleh. Tried using rubbing alcohol to clean it up but it didnt' help much... I don't know if the rubber's peeling or what (doesn't look like it, but it can't have that much gunk either... I've scraped and scraped) B) the contacts on the recharge station are getting worn and it's a bit finicky to drop in to recharge. I've been looking for a replacement but Logitech seems to have shied away from wireless gaming mouse (if only they'd have made a G7 with two thumb buttons and/or better battery life!)...
I've never had lag issues with it or problems waking it from sleep after long pauses, BUT, I did have to exchange it when I originally bought it... I'm not sure if this is widely known but Logitech actually shipped a ton of them with faulty bases that wouldn't work properly on a USB port (they'd work okay on a PS/2 port).
This happened not too long after it was released. Mine would even skip randomly and stuff... After some research online I took it back to CompUSA and saw that they actually had two different box designs in stock, and they had tons of either... The original box design allowed you to see the bottom of the mice (by the serial number you could tell which had the faulty base station), the newer boxes all had fixed/updated stations I think. I actually like the side-scrolling thing with the wheel too... And I love the placement of the rocker front/back button.
The only slight ergonomic issue I have with it is I wish it were a lil' longer or wider at top right. I'd enjoy more room for ring finger or back end of my wrist. Sensitivity switching on the fly would be nice to have with my next mouse....
Anyway, so I'm looking for a replacement, I guess I don't really need it to be wireless, but I remember fighting the cord a lot back in the day with my Mouseman Optical... I guess some of these braided cords I've seen on the G5/Ikari might be more docile. The MX1100 looks intriguing, though I've yet to see it at a store, I'd love to hold both it and the Steelseries Ikari in my hand... I think for prolonged use I'd actually prefer the shape of the G5 a lil' bit more to that of my MX1000... It's a lil' longer isn't it?
The Ikari looks pretty wide, I wonder if that would actually fit me just right, hrm. I haven't seen that one locally anywhere either, what a drag. I guess the G5's rough surface probably gets less dirty than the rubberized surfaces of the MX/Ikari huh?
Went from my Logitech G7 to a Microsoft Sidewinder....definitely thumbs up. Custom weights ftw.
The ergonomics of that mouse put me off to it.
Using an mx518 currently, fits my hands well, very responsive and i LOVE the two side buttons.
Unfortunately its dying, i keep hearing the BUBOOP BOOBEEP noise as if a usb device was just plugged / unplugged. Something obviously wrong with it, thats why im browsing this thread looking for shopping advice.
Have had it for 5 years at most.
I love the Trackman. The cordless one is nice, too. It does give you hand cramps at first, since you aren't accustomed to all the thumb movement. You get used to it quick, and it works well.
I used one for years and never got used to the thumb cramp. so I moved onto a Kensington http://www.shoplet.com/office/db/g15875.html expert mouse pro. then after that I got the Kensington http://www.newegg.com/Product/Product.aspx?Item=N82E16826125017. that trackball is bad ass. I love the scroll wheel on it too.
Have the G5 rev. 2 because I had an MX-510 before that and a MX-300 before that. Pin point accurate, 2 thumb buttons, non-sweaty surface, cool blue cracky design, weights, perfect fit for my massive palm.
