R7-1700X here, no overclock (just bog standard out of the box) utilizing a Silverstone NT06-Pro + Noctua A12x15 PWM in a 'push' configuration, all housed inside a Raven RVZ-01B case.
I put it under a bit of a 'torture' (in quotes due to not having full CPU utilization) by closing it in the media center (no intake/exhaust fans in the media center yet) and played Fallout 4 for ~90 minutes or so, while logging via HWiNFO64.
I got a max temp of 71.1C, max CPU usage of 36.5%, and max fan speed of 1726rpm.
The 1080Ti in the case hit a max temp of 64C, 1263rpm (It's an EVGA SC2 1080Ti) and reporting 66% total load.
I think the video card is fine as-is. I've got a pair of Noctua NF-F12 Chromax fans as intake fans directly under the GPU, so I think it's getting plenty of air, especially with HWiNFO reporting only 34% fan usage. If it matters, I have the pair of NF-F12s on a Y splitter, so they are controlled together (uncertain if the Y splitter might alter the reported fan speeds?)
I am thinking the CPU could use some more cooling, however, as the fan I'm using only has another 100rpm of speed left to it.
Thoughts?
*edit* Fan orientation for the NT06Pro is underneath the HSF, blowing away from the motherboard (up and out of the case), if it matters.
*edit2* I'm using the 120x15mm fan rather than a more 'standard' 120x25mm fan due to RAM clearance issues.
*edit3* I'm running Patriot PV416G340C6K 16GB (2x8GB) 3400Mhz DDR4 ram on the board. And so far - it's rock stable running the XMP (3400Mhz) profile. I *could* replace the ram with lower profile RAM, and go with a thicker fan, but not sure I want to give up the fast RAM I'm running on the B350-i ROG STRIX board, considering how sensitive the Infinity Fabric is to RAM speeds...
Thoughts?
