There is a search function for a reason. USE IT.
If he has to answer this question so many times, he could at least put it in the readme or something or manual.
the guy banned me !
now I'm really pissed, you try to help someone and this is what you get
is there something wrong in asking the Author for support ?
There is nothing wrong with asking but you are asking the same question that people already asked over and over again. When he didn't want to answer the same question, you are badmouthing him instead of doing your own research .
i did my own research, i solved the problem and I PM'd him with the solution ( in case he didn't know ) . At least he could have pointed me in the right direction
He bad-mouthed the author because of the author's arrogance.Rivatuner is probably the best damn free utlility out there. It's not for beginners unfortunately so the author's suggestion for you to migrate to evga precision may not be such a bad idea. You shouldn't
bad mouth the author just because you can't figure out how to work it. That is very childish.
why he should be helping me instead of closing the thread.
1. Drivers should be in the exe setup file
or
2. There should be a document somewhere saying the installer needs a .rtu file.
If he had done that, I would have researched and solved the problem myself
Maybe I expected too much out of Alex, all the other software author's I have met, have always been willing to help. Maybe he is the first of a kind i have met who did not help.
Writing good software doesnt exempt you from being a dick.
Well until you guys write something better, guess your just going to have to live with it eh?
<clears throat><serious tone> Thanks for teaching us the acceptance of life's circumstances, because it is certainly true that the author's attitude is one of those invariabilities that we must totally accept. Change is a hopeless wish.Well until you guys write something better, guess your just going to have to live with it eh?
Unwinder does come off as an arrogant prick quite a lot. He definately is not a people person.
Thanks OP, for this topic. I stopped using RT a long time ago, now I have no reason to even think of using it again.
<clears throat><serious tone> Thanks for teaching us the acceptance of life's circumstances, because it is certainly true that the author's attitude is one of those invariabilities that we must totally accept. Change is a hopeless wish.I know that you have taught me, personally, to begin supporting selfishness and delusional arrogance as a completely worthwhile way to live in this junglelike world of harsh, immobile realities!
Long live the dictator in all of us!
It is the best of which we can hope.
Thing is he really didn't act like a prick in that thread over at guru3d. The OP is just
throwing a tantrum because the author didn't want to hold his hand through what is a very simple installation of RT...![]()
I feel sorry for the author, this is really going to hurt Rivatuner Sales...![]()
If he is unable to help then he should refrain from posting, unless he gets a kick from calling everyone a noob and boasting about how awesome (he thinks) he is.
In this case he, in all his arrogance, condescendingly called the OP an ignorant noob for something that was out of his control. Like the signed drivers not being included with the installer, maybe?![]()
Unwinder on Guru3D said:Unreal, unless you downloaded some third party RT distributive or manually moved installer file to custom folder and forgot to copy the update (*.RTU) file there. Installer automatically offers you to install all updates located in the same folder and Guru3D always distribute RT with an update containing a driver signed by techpowerup.
Someone has posted a link in the 4th post but instead of following the link, I guess that it is easier to ask, AGAIN, right?![]()
if he does not want to help people use his software why bother working on it and release new versions?. what a clown.
