Wave Master fan replacement
fsh42na
Do you know of a way to replace the 2 stock intake fans in the front of this case? They are sleeve bearing ones that I want to replace with ball bearing fans. I'm used to cases (Lian Li, lately) that allow you to snap off the front panel to install/remove fans. The front panel of this case seems riveted or possibly held in place with hex head screws.
Thanks for any help. :confused:
I heard the bezzel was removable but was a PITA to take off, I know the Praetorian's is removable and the cases are nearly the same, I'd assume both bezzels mount in the same way regardless of how they look. Gotta take off the side panels and inspect it well.
