Well I just finished building my first computher a few weeks ago and love it. Though I've decided to go ahead and water cool it. I've done some reading on it and would still like some help from the pros on what to use. This is what I'm thinking...
DD12V-D5 Pump Variable Speed
Black Ice GTX120
Danger Den Round (Cylindrical) Reservoir
Copper TDX Block for Intel 775 Processors
DD - 8800 GTS
Then as far as tubing, fittings, liquid, etc. what is suggested? Anything that is cheaper that I can/should use?
BTW the comp is...
Cooler Master Stacker Case + 7 120mm fans | OCZ 700 Watt Power Supply | EVGA NVIDIA nForce 680i SLI ATX Intel Motherboard | Intel Core 2 Duo E6600 Conroe | EVGA GeForce 8800GTS 640MB | Western Digital Raptor 150GB 10,000 RPM & Western Digital Raptor 74GB 10,000 RPM HDD's | Kingston HyperX 4GB DDR2 (PC2 7200) | Sony DVD-RW & DVD ROM | Internal Card Reader | X-Fi XtremeGamer 7.1 Sound Card | Windows XP Pro
May not be the best install but for my first I'm happy with it
http://www.picturetrail.com/gallery/view?p=999&gid=15845743&uid=1612587&members=1
Black Ice GTX120
DD - 8800 GTS
BTW the comp is...
