Hello,
I recently got a D-link DIR-655 router and am running a wired connection to my PC. Every time I shut down, the PC turns back on in a couple of seconds. When I either (a) disconnect the Ethernet cable, (b) connect the cable to another router, (c) connect the cable directly to the modem, or (d) do a hard shut down, I don't have this problem (PC stays off).
Here is my setup:
Asus P5GD2 Premium motherboard (Socket 775)
P4 3.2GHz Prescott
Windows XP Pro SP2
I am using the PCIEx GbE LAN. In the BIOS, here are the relevant items that I have enabled/disabled:
PCIEX GbE LAN: Enabled
LAN Option ROM: Disabled
Onboard PCI GbE LAN: Disabled
Onboard WIFI Controller: Disabled
Power On By External Modem: Disabled
Power On By PCI Devices: Disabled
How do I disable this feature on my mobo? Is this is a mobo issue? (I'll later try to disable the feature on the router, but I want my mobo to be secure.)
Thanks.
Here is my setup:
P4 3.2GHz Prescott
Windows XP Pro SP2
Thanks.
