how much longer do you think for mini-itx b/c i have to finish my build before i move -_-
I heard non K versions of Haswell (T versions) would have locked straps. Only K version would have straps for sure.
I didn't wait for Haswell because the differences between the 3770k and 4770k would be minimal for I do. I'll have an Asus Sabertooth Z77 and 3770k on Wednesday.![]()
At stock the difference would be minimal... For OC purposse the difference will be abismal...
really? what kind of clocks? what source?
What if used a 40x multiplier (for the max 80x will be available for unloked chips) 175mhz x40 = 7.0ghz.. Without touch voltage... What could the possibilty of a chip of that type?
Will pretty much the same on K series with unlocked multipliers up to x80 (so 8GHZ without touch the blck?? Just crazy), now the difference its the blck have 3 bases 100-125-165 as far i know, with a tolerance of extra 5-7% per base if we do that they blck can be raised to 173?, so between 65% to 73% increased performance for non K models without touch any voltage??... Thats a big change on the limits of OC, cuz the main base blck on haswell remain at 100mhz...
Translation by Calbert.Brief translation of the Chinese article(Main points only, too lazy to translate the whole thing)
Title: Disappointment: only haswell with K support overclock with blck
The site received screenshot of cpu-z showing blck of 184.82Mhz on an i7 earlier and has now received an i7 4770k and a e3-1280 and is investigating them.
First screenshot shows that the 4770k can indeed do blck and multiplyer overclock as expected.
2nd screenshot of the e-3 1280 shows blck of 100mhz. They tried multiple z87 mobo and found the blck option grayed out and cannot overclock it.
They conclude only the K series of i5 and i7 have unlocked multiplier and blck, and will further investigate the samples they got.
I plan on upgrading from my 920. I've waited this long, no point in getting ivy now.
No one knows.Sorry if this has already been answered elsewhere but are Haswell CPU's soldered again or same like Ivy?
I'm on an E8400, and I plan on going balls out with Haswell. 4770k, 32gb ram, most feature rich motherboard I can get my hands on. Then I won't upgrade for either another 4 to 5 years or if someone decides to Conroe the industry. Honestly, that's what it takes to really blow one's mind with an upgrade, otherwise it's not really worth it for 1/4[H] people like me.
I think the number is higher than 1/4. I upgraded too from E8400 to i7 2600. And i'll skip haswell and broadwell.. I'll upgrade on skylake if my actual system make it possible, the only way to upgrade if is my actual system are broken... This could help to spend some money in other things like GPU
Lost my motherboard last Monday and was having this same debate - a good friend of mine is an engineer at one of the fabs out in Hillsboro, OR, and his advice to me was if I was concerned with saving a few watts of power, wait for Haswell; if not, just get the current i7 and move on. So that's what I'm doing.
Or you can wait few days more, when the price start to drop due to the arrival of IB, yoy can save some money too... If not wanna save money it truly worth to wait for haswell.. If you cant wait.. Well.. Nothing much can be done.. Just go on with Ivy Bridge...
As someone that's been using a Q6600 since 2008, I'm definitely holding out for Haswell.
Now I'm left wondering if HyperThreading is really worth it.
I will hold on to my i7 2600k a couple more years. Fact is if you play games now days with a single monitor the latest intel haswell/amd cpus with the internal gpu will run most games good. Being most games are just console ports and the new consoles to come out will be just slightly better the need of having dedicated graphics cards, sound cards etc are ending.
I really don't understand why people pair awesome CPUs with shitty GPUs. The only time CPUs are remotely stressed nowadays is basically just in games, and that's only IF you have an awesome GPU to pair it with. Really...why spend twice as much on a CPU that's twice as powerful when only ~1/4 of it will ever be used in even the least GPU bound games around...people should buy a balanced machine for the same price that runs games at 5x the framerate at the same settings..
