nobody_here
- Feb 1, 2006
gurgle said:excellent. you running stock cooling? i want to do this too, but i havent found a good aftermarket cooling solution yet.
have you looked?
96redformula said:Nv Silencer Rev 3, had to cut about 1/4inch off so it is not too long. My temps are 45idle and 68load, I dont think they are right, but it is below 70 anyways so I am fine with that.
Speed before voltmod 550/1800
Speed AFTER voltmod 650/1800 artifact free, have not tried further.
danbanger said:excuse my ignorance but can you use a regular lead pencil to draw the line?
scwam said:What happens if this is done on the standard 7900 GTX that normally runs 650/1600?
wonkman said:There are different mods for the 7900GTX to raise the voltage. I believe that the GTX already runs at 1.4 so even it you could do this mod, it wouldn't help.
scwam said:So, I'm wondering since this is so easy on the 7900GT if I did the wrong thing in canceling my step-up to the 7900GT superclocked for $50 extra overall cost and instead renewing it with a 7900GTX standard edition for $202 extra. Maybe I should switch back to the superclocked? I can't run past 1280x1024 but I've got a dual core that runs 2912 mhz that I don't want being bottlenecked. What would you do?
jbean7457 said:ok, just finished the simple 1.4v mod using a conductive pen from radioshack. Speeds went from 564/1740 to 649/1780 stable. I could probably take the core up a little further, i'll have to mess around with it later. 3dmark06 went from 5450 up to 6018.
Load temps went up about 7c (57c).. but part of that probably has to do with how warm it is in my house tonight.
computerpro3 said:just busted 710/1850 24 hours ATItool artifact testing stable. Thats with 1.55v and only 2.09v on the memory. I'm going to up the volts and aim for 725/1900 24/7.
Oh, BTW thats on a $290 shipped refurb BFG![]()
Silverado SS said:well I just cleaned off all my AS5 and put on a fresh coat of it, then cleaned off all the conductive ink and made a new line, and still no go, will not overclock any more.
jbean7457 said:weird thing with my voltmod is that coolbits would not detect any higher than it did before the mod. I just started messing around with the sliders and found a stable setting. So far it has passed multiple runs of 3dmark06 and hours of BF2.
Sucks that yours won't go any higher though![]()
The_Dark_Abyss said:How long did you wait for the conductive ink to fully settle? It usually takes several hours for it to reach full conductivity . . .
scwam said:So the 7900GT is that easy huh? Do you notice a difference in fps at all? Is gameplay smoother?
scwam said:I wonder know if I should just cancel my 7900GTX step up which will cost me $202 and seetle for the 7900GT Superclocked for $50 instead and do a volt mod.
