That's what I was wondering about. If the 7900GT is like the 7800GT, bumping the voltage by 0.1v should be easy with a BIOS edit and flash.aldy402 said:Does Nbitor recognize the 7900GT's bios yet?
Jiggaman2576 said:I just read how to do it on VR-Zone. I am curious about this also since I watercool and these cores are much cooler. Here is a picture of what you have to do:
If you mod it soon let me know your progress, I'll have my card in 3 days and I might just Vmod it before I bother to put it in since I have access to everything required at work.
pandora's box said:nibitor currently doesnt support the 7900 series. me and several other people at xtremesystems.org tried modifying the gt bios to have 1.4 volts and it didnt work. hopefully mavke (creator of nibitor) can crack it.
Kangg said:Further in that same thread theres an even easier way to do a 1.4 vmod for the 7900 GT
http://www.xtremesystems.org/forums/showthread.php?t=92874&page=7
PX Vertex said:http://www.xtremesystems.org/forums/showpost.php?p=1355686&postcount=162
well, same post as ^ but this is what i'm gonna do
Jiggaman2576 said:On a different note, how safe is it to run a chip like this at 1.55V because I'd have no problem doing it if it could handle it for atleast a year![]()
Silverado SS said:where can I get conductive ink?
And I thought Fry's overcharged for conductive pens and paint.jbean7457 said:scroll down to conductive silver paint
http://www.semsupplies.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=MEMS&Category_Code=SSAA
jbean7457 said:this voltage mod stuff has me interested. Can you voltmod with air cooling (Zalman vf700cu)?
Silverado SS said:where can I get conductive ink? Would AS5 work to make the bridge? Are there no softmods out yet?
Sikish said:Go to auto store and get Rear Window Defogger Repair Kit.
Jiggaman2576 said:I managed to pull off 710mhz on the core with the 1.55V mods in place. I had to lower my memory to 1580 (790) to get it to stop artifacting. I have some ramsinks on the way and a slot cooler that I hope will cool them off so I can run them faster again. Almost broke 11K in 05 however I am not running my ram 1:1 so I have some G.Skill 2GB PC4000 on the way that should do up to 275 1:1. I'll report back but so far this is the easiest mod I've done with the biggest performance gain. If you got the cooling, you should atleast do the 1.4V mod to make it the same as a GTX.
Jiggaman2576 said:They have figured out how to do the Vmod and its VERY easy to do the 1.4V mod. There are other mods that can be done to get you all the way up to 1.7V Google 7900GT Volt mod and you should find the site with the info. Linkage For those of us that are too lazy to read all the info on this, one guy reported going from 550 Core to 675 Core by doing the simple 1.4V mod. I am going to test mine tonight since that is what my core was limited to before as well. Happy day!
Jigga
nobody_here said:or go to Radio Shack and get the real deal
http://www.radioshack.com/product/i...04395&cp=&kw=conductive+pen&parentPage=search
what u using to OC? my coolbits only lets me go to 530/816Jiggaman2576 said:I haven't done any Vmem mods yet, and I am not sure I want to risk frying it. They run so hot already, more heat would suck. I think I just have to break it in, I ran it at 1800 lasntight again and I had no problems.
gurgle said:what u using to OC? my coolbits only lets me go to 530/816![]()
excellent. you running stock cooling? i want to do this too, but i havent found a good aftermarket cooling solution yet.jbean7457 said:I just bought a conductive pen a radio shack ($12.99) i'll post in here with results as soon as I get a chance to do it.![]()
