It seems to be finiky... I know it wont work when i have some program open, cant recall that particular program though... mightve been acrobat... not sure.fallguy said:Flip3D has never worked for me. Aero is on, and working, Flip3D just doesnt work for some reason.
TheRapture said:You are hitting the "windows logo" or "start" key + "tab" right? .......NOT, "alt + tab" ?
keep pressing the tab button once you've accessed it while holding the windows button down, it cycles through all your open programs, let go of the one you want up frontXaeos said:Okay. So... can anyone tell me the point of this function? I hit and hold Windows+Tab, and things have a nice graphical zoom out and tilt effect, but... what does it do really? As soon as I let go everything goes back to its normal place. I'm... not sure what it is supposed to accomplish?
PLEASE!Obi_Kwiet said:It needs AA really, really, really bad.
yupRofl-Mic-Lofl said:Kind've curious. Does this do the exact same thing as Alt+Tab just...."prettier"?
