secure.boy
- Oct 22, 2007
I have IBM x3105 server with 2 pci 8x,and 2 pci slots
is possible to put vga on that mobo?
pci express 8xDo you not have any video at all? I'd generally expect integrated video.
There are lots of PCI video cards available for pennies. I suggest a Matrox Millenium or Mystique for quality and stability.
What's a PCI 8x slot? Do you mean PCI Express 8x? You can use any PCI-E video card in a PCI 8x slot.
pci express 8x
it has ati with 16 mb ram
but i want to use as workstation
i want to put in nvidia 7300 can i?
how?
okbuy it and put it in?
ok
but the connector is not same with PCI-Express x16??????
ok
I hope your not referring to a PCI-X slot. Please give us a link to an image (newegg). I would like to see the board. It's the only way to be certain.
Just plug it in. It'll work.
PCI-E cards are all backwards-slot compatible. An 8800GT will function normally (albeit with much slower 3D performance) in a PCI-E 1x slot, despite all the pins that are hanging out unattached.
