_mockingbird
- Feb 20, 2017
They still can't measure the die size properly lul.
Reminds me of story with Ryzen where measurements vary from 193 to 210.
Maybe the die size has Ryzen
Sources? Links? Are you the source? Sorry, I don't know who you are.
Die size readjusted from 560mm after GamerNexus did their measurement.
RTG is apparently pretty bitter about reviews of Radeon Vega FE that have been published and is considering denying sample units of Radeon RX Vega to sites that published reviews of Radeon Vega FE.
This is not a done deal and may not happen, but is currently under consideration.
Note: RTG functions as a semi autonomous group inside AMD akin to Hong Kong so whatever happens inside RTG doesn't apply to the rest of AMD.
Performance is basically half that of OCed GP102 @ 4K. Can't beat a GTX 1080 FE and draws more power than a Titan Xp during gaming.
Interesting choice of GN to remove / not include GTX 1080 FE @ power consumption chart.
Raja responded to PCPer's amended die size measurement (now 512mm²) by saying the actual size is the closest perfect square.
I just spent 10 minutes of my life trying to convince a random guy on the internet that 484 is not, in fact, closer to 512 than 529.
Still doesn't believe me, insists it's 484.
Edit: just saw post above, seems like it was in reference to 500mm figure?
Ouch, well at least it was only 10 minutes. But ya, I think Raja meant it in relation to the 500mm figure. Unless he was lying when he said it was smaller than 500mm, and in fact it is bigger than 500mm and therefore it's 529mm. Its not impossible for that to happen, except why lie about die size in the first place then? Unless he meant "closer" rather than "smaller" than 500mm. That's not impossible either. Unless his reply in the tweet indeed was also meant to correct that statement in some way. I guess.
Because AMD can't answer a single thing clearly.
http://www.gamersnexus.net/hwreviews/2973-amd-vega-frontier-edition-reviewed-too-soon-to-callIn our conversation with AMD, the company was big on the fact that it's a pro-ready card with pro drivers, but that it also has gaming drivers packaged in; this is somewhat similar to a Titan Xp, except (theoretically) with more pro-level optimization. That makes Vega: FE a very odd card
Even 484mm2 is still more than double Polaris size, with less SPs that a double Polaris would contain. Which is rather curious.
That was my take as well: the guy can't give a single straight answer. We all can do the math, but does he seriously think being coy is a good idea at this point?
Pascal had minimal regression in IPC too in order to maximize frequency. Maybe NCU was also redesigned to finally overcome GCN frequency wall.
From 3DCenter: Fury X @ stock vs Vega @ 1052 / 800mhz. CPU is different but it doesn't really matter that much in superposition. That's a quite big regression in IPC compared to Fury X if you ask me. I guess we can rename NCU to SCU (slow compute unit).
I dont know if HBM will play a significant role but I do know at extreme settings in that benchmark memory bandwidth does play a role especially with HBM it should. But regardless I think AMD just did a bad thing launching this card and they should have enabled game mode after rx vega was launched. I do believe these guys are very incompetent and their driver team is no where near good as nvidias and they should really get their shit together. They made a mistake making a half ass attempt at launch. Launching a product that is not for gamers but has a half baked game mode and that is not certified for professionals. Its like a fucking titan xp not advertised for gamers but does a little better in pro software but then you have quadro cards. IDK I do think that they are having some driver issues that they are working on other wise I see no reason to not have RX vega already even if its a turd. Just take a loss and release it, but looking at FE where its all over the place it does seem probable that they have their shit cut out for them and raja does wish this was based on polaris lol..well they want to compare IPC so bandwidth part probably not that important.
Might have something to do with the 1H 2017 deadline. Saw the same with Ryzen, release before things were settled and ready. The hope here as with Ryzen is AMD being able to improve things, like BIOS updates, driver updates, etc, etc.
Still had 1 year to get the drivers ready, that should be more than enough time.....
Is the HBM shortage/difficulty still the primary guess why Vega is late?
Iso who was sleeping? Sounds like some one was high lol.
