He was getting like 33mh/s.. heck my fury X was doing 28mh/s
Yikes!!!
I expect the usual shills around here to go pretty silent about Vega and they'll go #WaitforNavi
This is not the gaming card, but their prosumer card and AMD has stated the gaming card would be faster. If you waited this long for Vega I think 1 more month to know for sure is not out of reach. But most of this thread is just full of vile and why I just tend to avoid it.
Nooo, I really need to migrate to green side if I want more performance
There are evil men on that side, even on this forum![]()
Don't fool yourself, AMD is just as bad or worse.
Live testing summary:
- Time Spy Graphics = 6875 pts
- Doom Vulkan 4K Ultra @ 55-65 FPS
- The Witcher 3 @ 28-35 FPS at 4K Hairworks on / 41-42 FPS with Hairworks off (80 C running the game)
- Troubles OCing past 1650 MHz with the blower
- Tried to OC HBM, starts at 945 MHz, managed 960 MHz stable and at 980 MHz it got too hot
- Tester says you won't be able to OC without additional cooling, thermal throttling (80-85 C)
- Tester put 2x 80 mm fans to help (open air case) and it was down to 75 C
- Tester doesn't think it will touch the 1080 Ti performance-wise, only 1070-1080s
- Mining: 30-35 MH/s
- Cinebench R15 OpenGL: 97.39 FPS
- Initial testing done using Pro drivers, then switched to the Gaming drivers and performance didn't change (37-42 FPS @ TW3 4K HW Off)
- Card operate at 1348-1528 MHz in gaming mode during The Witcher 3 testing
- >300W for the GPU alone
Remember when I said this was going to be 1080 level, last year, where's the I told you so button...
Pro drivers and Gaming drivers not affecting performance might be a clue something is up.
Not really, quadros are pretty much the same thing in many games, actually the p100 version quadros perform better at times in games too. Really depends on the game.
So benefit of the doubt 10% faster in games for rx Vega. Even with that, its going to be not so good if its more than 450 bucks.
That may be true but using Nvidia as reference to how a AMD card will perform might be a bit of a stretch. They may have broke the gaming driver on purpose to keep people in the dark on how the gaming side will do. But who knows, I look forward to seeing the gaming version and I hope it's competitive otherwise it's not good for us consumers.
Oh for pete sakes, you can't say crap until AMD does the driver optimizations. When we run pre-release build we have all kinds of diagnostics built into our code to analyze performance (which in fact slows it down) and to promote stability. These alone cost us over 20% performance. Even the press from AMD says the gaming drivers are ready yet. Right now they concentrated on professional drivers because they are what is being released first.
As usual more d*ck swinging by fanbois from both sides who wouldn't know how things work if it hit them in the head.
So put your clubs away until AMD says, "These are the official release drivers for gaming." Then we can crucify them if they deliver 1080 performance > 1080ti price.
It's a 14nm Fury GPU with HBM2, are you claiming the Fury platform hasn't been optimized by AMD yet?
So put your clubs away until AMD says, "These are the official release drivers for gaming." Then we can crucify them if they deliver 1080 performance > 1080 price.
Waiting for AnAndTech Review, some of the tubers will probably start yapping away tomorrow as well. I would like to know the ceiling when properly cooled on the clock speed - if the clock speed is lower due to thermal throttling than data so far would be skewed worst then it's potential. To bad the water cooled version is not available yet but I get the feeling the water cooler is too small for it -and probably not worth the extra $500. Hmmm, might be able to pick these up in a couple of months for less than $800. Has Raja shaved yet? Bald? So he can hide.
I said the same on AnandTech and got banned.
And probably got attacked for it.![]()
It'll be fine. The cooler on the Fury X can keep the 275 watt Fury X at 60-65* at 100% load and 50% fan all week long. What's 25 watts more gonna do? 55% fan? It's a nice thick quality rad with plenty of cooling headroom. I've been mining on my Fury X the last week. No concerns with a pair of them in the cosmos 1010 case I have running full tilt. The side panel even stays on!Yeah a small radiator like on the Fury X isn't going to be worth it unless they do 2x140mm likewise. It's a lot of heat AND they put the vram near the die making it even worse.
A giant air cooler will probably be best... or a big AIO/custom water.
Trying to use a blower at this wattage is hilarious. I get why, but maybe they should have made it an extra slot deep.
