But I will admit -- I have a Fury X, and my Fury X scored mid 14K on a 4770k overclocked to 4.5Ghz.
http://www.3dmark.com/fs/8467364
Just look at your graphics score only, not the total score
Don't be too concerned with that score being 17,000. As someone who does stuff with futuremark, that score is lowered by the CPU used. If an overclocked 7700K was used here that score would likely be in the low 20s (based on my experiences)
Example given: Here is a 1080TI with a 7700K @4.8GHz and 32GB of PC3000 RAM that I built.
I assume you are being sarcastic, but if not - Future Mark doesn't care what your desktop resolution is. It still benchmarks for stated default res. My desktop "building station" has a old Dell 2007 FP monitor that is 1600x1200. Score is immaterial of your monitors native res.Archaea you're a phoney! a big phat phoney! 1600x1200 display. 1080Ti
¯\_(ツ)_/¯
On a more serious note, I think I am officially tired of waiting for Vega, there isn't even a review yet... It feels like I have been waiting for 20 years
~1500 ? what? mhz? where are the clocks reported?
Being "someone who's done stuff with futuremark" I'd think you'd understand the difference between the overall score and the graphics score. 23k for the Vega FE and 28k for your TI.![]()
AMD did give out samples, but they went to developers. Sebbbi for example and probably many more. Considering the DX12.1 top tier everything, there is probably a lot of work and research to be so there. Devs don't need the performance, just enabled features to get started. Maybe in a month some features will be patched into games.Only way I see Vega around 1080Ti speeds is if it can maintain it's clock at 1500+. The gaming cards with better cooling hopefully will be available. I do like the Pro aspect to the FE, just want to see some solid reviews on it. Do not know about the excuses for not giving out samples - if you have a hot product, have much faith in it, it clearly performs well - I would think you would Damn well get as many samples out there to be have it broadcasted as loud as possible. As for the FE, I would like to know more about what software it supports well in Pro Mode - a list that is. I will see if AMD has anything about what software it performs well in.
I doubt the cooling will matter much, but getting rid of 8-Hi HBM2 stacks with their thermal issues will help. Along with early benchmarks using 550W power supplies and probably weak CPUs.
well if there's on positive thing to come out of this spectacular launch it's that r/AMD seems to be collapsing under its own weight
Anarchist4000 I struggle to see how primitive shaders will effectively improve its performance. If you offload rasterization to the shader array as a compute shader you are simply taking away resources from the pixel and compute shader portions of the render. So this will only make sense insofar as the load is balance to provide the optimum framerate which will necessarily be lower than that of the competition in this case (no geometry bottlenecks)
lol $1200 card is neck and neck with my $400 oc'ed 1070.... this won't go well for AMD
I don't think Navi is a Vega replacement, cause 7nm is not going to be ready anytime soon.
What would be totally funny consumer Navi drops HBM like a bad date, and the HBCC works on traditional vram and other memory types lol.
Love how people are conveniently overlooking the fact that the guy who has this card doesn't seem to have that much of a clue what he's doing. A barely adequate psu and its questionable if he's even got the right driver installed. But of course that won't deter the trolls from spreading their shite.
They have already announced navi will use a new memory type. That said I'm wondering if instead they mean SSG and will keep HBM especially if they do MCM - they might go GDDR for the mid-low end cards though like Polaris is.
HVM 7nm from GF is 2H 2018. Could see Navi late q4'18 to q1 '19. That's not so far off.
gaming drivers are available on AMD's website, they were posted earlier this week.
And from what ive seen some people say, he hasn't got them installed.
Did you check videocardz link? They are using gaming mode.
Alternatively, AMD could have sent around review cards to avoid the whole mess.
One post mentioned hes using a driver from jan 2017. He seems to have vanished for the time being anyway. I know pc per has one of these on order, would prefer to see what they think.
They could have but as they already stated in the 25 min video this card isn't the gaming iteration which is still coming next month at some point.
This is just another delay tactic. The gaming iteration isn't likely to be much faster.
Check is post in the thread underneath. He is using the latest drivers.
Results from the 3DMark Fire strike, as of now is on level of 1080. I have dig on the drivers as they are not showing correctly and I've downloaded correct package from AMD but I've used half pro and game drivers now I will use just the gaming ones to see the difference.
Well that is pretty far if Volta is coming early 2018
If Nvidia did go 12nm as TSMC says then that's not the case. 10nm was scrapped, they moved to 12nm and 12nm doesn't start until 1H 2018. So there could be 5-6 months in it at most if AMD doesn't drag their feet, e.g. Volta late Q2-Q3 2018 and I bet it'll be the piddly x80 Volta too, not big.
It appears there may be a uarch advantage to AMD for once. And possibly a scaling advantage with MCM. I wouldn't write navi off if GF is already moving on to 5nm with IBM currently.... AMD might have a decent uarch for once scrapping GCN and most of the efficiency disparity could be gained back. Throw in process and scaling you might even see AMD kicking ass outside of mining in recent years. Time will tell if they can make something of navi.
Also with Vega, it sounds like we have a Gaming Ryzen v2.0. Wait for the drivers and never be a week 1 or 2 AMD owner lol (that's coming from an AMD aficionado).
That's what we've expected for the last six monthsSo its around 30-35% faster than Fury X according to 3dmark... good job AMD![]()
As far as I know all NVIDIA cards have supported feature level 12_1 since Maxwell.From an AMD guy. So ahead of Pascal with Binding, Conservative Raster, UAVs, etc.
