Users Abandoning Microsoft Browsers At Record Rates
Megalith
24-bit/48kHz
Data released earlier this week would suggest that IE and Edge “hemorrhaged user share at an astounding rate” while Chrome continued to grow. Firefox also saw a decline.
IE and Edge combined to account for 38.7% of the global user share -- a stand-in for the percentage of all desktop and notebook PCs that ran those browsers -- in May, according to U.S.-based analytics vendor Net Applications. May's number for IE was down 2.7 percentage points from April, the largest one-month decline since Computerworld began recording browser data in 2005. In the last six months alone, IE -- a bucket into which Net Applications also throws in Windows 10's Edge -- has lost 11.4 percentage points, an unprecedented decline for any browser at any point in the last 11 years.
Seeing as they still don't have file drag and drop for SharePoint working with Edge after it's been out for a year I can see why... They basically have put no effort into it.
Not sure if this is the same for others but when I finally switched to chrome, I just didn't bother going back. IE in the past didn't work well for me, so I changed to something that does. As long as chome keeps working for me prolly going to stick with it.
Back before Microsoft started this agile development nonsense it seemed like they would start all sorts of neat projects and then abandon them after a version or two. Now they do the same thing, only faster.
It wont be the last thing they hype up and then practically abandon. They don't want to support more features than they have to.
I honestly don't know why Microsoft continues to sink effort into web browsers....they historically have always sucked.
My work still uses IE, usually outdated versions. Either there is some advantage in a large centralized deployment, they are lazy, or clueless, or all of the above.
I don't think this is a big deal. Before the latest wave of embracing web standards, there was already declining support for specific browser features. At one time, like in the XP era, IE could have been a necessity for compatibility with certain applications running in a browser. MS used this and pushed for lock-in to keep Windows at a high usage level, especially in the consumer space. I don't think it's as big of a priority anymore. Consumers still use Windows on laptops and desktops, and MS has largely shifted revenue to enterprise licensing. It's no longer important that IE is used to ensure Windows dominance on the desktop. It's past that point.
My laptop is a POS. Unstable (even with a full compliment of "OEM" drivers, and just as unstable without) and prone to sudden display driver crashes (why? The event log is patently unclear on why), IE, Chrome, and FF are unable to properly recover after my display driver crashes (which happened nearly every day, before the latest Intel IGP driver update with installed - over the complaints of the installer that the driver was "incompatible" with my POS DELL E6450. So now I use Opera. Then I notice MSFT is still pushing Edge. I can put up with the lack of a proper adblock and any extensions at all, really. What I cannot put up with is a "modern" browser that cannot survive several sleep/standby cycles (its a laptop that gets carried around every day) and cannot recover from a display driver crash.
So.... back to Opera. I have no clue why it works, while Chrome crashes.
I use Portable Firefox for general browsing that is all locked up tight and IE for forums that I log into. Chrome seems too cartoony or plastic(y). Feels like it is holding my hand or something. Plus I have a growing disdain for Google and their ideals. Maybe I will giver Opera a shot. I haven't used that since I cant remember when. Maybe Windows 95 days.
Gnawgnu's Realm: Fix for Wake after sleep freeze on Dell Latitudes
Maybe this helps your issue.
It's because the Chromium team decided to Hooli-ize/Nucleus the memory manager and made it unstable a few months ago. There are some command line switches and flags that can mostly fix the stability problems, but you're better off using Opera or Vivaldi because at least both of those respect its users.
Edge sucks. It's a bad wrapper for ie. Start it up, no homepage for you, we'll give you a busy mess of "news feed" and ads.
If you must use win10 on desktop or tablet, I don't know why as it's identical to windows 10 on my phone, then go to program files\internet explorer\iexplore.exe that's better, proper ie.
I use ie for general browsing and firefox for watching youtube because adblocker. Works fine. But I'm on win8.1.
Problem is its a sandboxed metro app (XAML instead of Win32) and thus lacks basic shit like that.
God awful, not sure why they thought that desktop users would want to run mobile crApps
I really dislike Edge.
I don't have too much of a problem with chrome and I use both chrome and firefox pretty regularly. Chrome does need to fix it's scaling problems though. It doesn't scale nearly as well as firefox and with UHD monitors becoming the new standard it's only going to become more of a problem.
Edge does suck for the reasons you listed and more, but it's not a wrapper for IE. :p It's built on a completely rewritten codebase (in the state is in now, at least; in early development it shared parts with IE), including new rendering and js engines.
I don't get why so many people use Chrome. Malicious extensions just seem to magically install themselves.
Have never seen that happen. Though I did have one or two extensions get updated (the authors got bought out) and turned into ad-ware.
Ah, of course, that explains why it's more phone like in the way you have to click twice as much to get the same things done ie just has plainly available. Like having to click the home icon to open the home page and having to click that ambiguous phone type icon then click favourites to get to your favourites. :)
I'm all for new engines and stuff, but when the interfaces are this bad I say no. I fired my sacrificial test win10 PRO laptop up yesterday after a few months of downtime, and after navigating the phone interface (why the fuck do I need flight mode option)? , to updates and make sure it installed them, reboot, hope it's better as it also had a major os update, nope, it's gone all factory reset. Everything was back to installed defaults. Using win10 makes me actually feel trapped and sick, but that just disgusted me.
Everything you just said here is incorrect. It's not IE at all and the Start Page is configurable.
If you're running Win32 apps on your Windows Phone I'd like to know what phone you're using.
It is interesting that for all of the "forced" installs how Windows 10 how easily is seems people are changing the default browser. Edge simply didn't have enough features to compete. That's getting a good deal better with the Anniversary Update, extensions and Ad Block, hurray! Even some touch enhancements like swiping backwards and forwards, something that was really cool with IE 11 modern that got dropped in Edge for whatever reason.
I think the Anniversary Update does fix most of the biggest shortcomings of Edge with extension support. Now the extensions need to come. In any case, it's still a better browser for touch, especially on lower end devices than Chrome, that's really something Microsoft has to do and it can't leave touch support up to Google that to this point has shown almost zero interest in anything to do with touch in Windows 10. While I understand that for phones, Windows tablets might need a bit more support from Google longer term.
They are killing off the rest of their loyal IE users by killing off IE... Edge is a joke, no one wants to use a metro app for a browser, and it certainly does not have anything that would help to retain IE users.
I like IE.....Edge was F'ed in the A though.
My only experience with Edge now is that it's the default application for opening PDF's.
I just set Chrome and Firefox (both with Ad-Blockers) on the task bar for customers when I do the 10 upgrade for them. Edge the Store and Cortana just get hidden away.
No one has asked for it.
Internet Explorer is fine, the last few versions but I miss the extensions. Once Edge has all the extensions Chrome does, I may use it on a day to day basis.
Everyone is jumping on the Chrome bandwagon, it is not MS who is losing users.
I've used them all. Chrome is fine but it crashed too much so I switched a year ago to Firefox.
Edge was crap. Used Firefox for 7+ years, and recent instability issues and glitches with Firefox forced me to switch to Chrome a few months ago.
Now that's customer service with a smile. Your customers are lucky.
I think the Anniversary Update does fix most of the biggest shortcomings of Edge with extension support. Now the extensions need to come. In any case, it's still a much browser for touch, especially on lower end devices than Chrome, that's really something Microsoft has to do and it can't leave touch support up to Google that to this point has shown almost zero interest in anything to do with touch in Windows 10. While I understand that for phones, Windows tablets might need a bit more support from Google longer term.
You are right, Edge is not IE. It somehow managed to be far worse than IE ever was. I didn't even think that was possible.
It has the Google marketing machine behind it, that's why. Firefox has always been a better browser.
When polls say "Chrome" are they referring to just the desktop or does that also include Chromebooks and Androids? I can't see that most poeple on desktop aren't using IE, but if you add in cellphones and mobile devices it totally makes sense (how else would Safari even be noticable???)
Many IT dept's really do not want to support several browsers so they pick IE, this is because IE can be managed though group policies. However, chrome too supports group policy. We deploy IE, Chrome and FireFox. While IE and Chrome are enterprise friendly, FireFox is not to the extent of one of the developers telling me he doest care about enterprise support. That dev was an arrogant ass. For that alone I wanted to pull FireFox from our district. As of now, we (IT Dept) tell people to use IE or Chrome with very limited recommendations to use FireFox. FireFox does not have native (non 3rd party) support for group policy.
Be in your IT dept shoes for second. Say if someone puts in a support ticket claiming the page is not showing up in chrome but shows in IE. End user refuses to use IE even though the site works fine in IE but not in Chrome. Now the user expects the IT dept to fix it. In turn leads to extra burden on the IT dept. My guess is they chose to avoid extra support tickets.
Supporting only IE is something we also did many years ago. We only deployed and supported IE. However, down the road this was not an option anymore, because teachers and students use google classroom. Our district now has 3,000 + chromebooks which is catching up to our 6,000 Windows based clients. Supporting Chrome on our Windows based computers was a natural necessity.
IMO, Chrome is easy to deploy and manage so maybe your IT dept has a valid reason?
If you feel motivated, show your IT dept these links:
Chrome enterprise: Chrome for Work: Chrome for Work
Group policy support: Set Chrome policies for devices - Chrome for Work and Education Help
If they don't have a valid reason not to deploy Chrome, but lack the know-how to complete the above tasks then they are indeed "clueless".
I ran into this with Edge opening PDF files; you have to change that in Control Panel, not Settings.
Instead of "left-click the Start Button">Settings>System>Default apps>"Choose default apps by file type", use "right-click the Start Button">Control Panel>Default Programs>"Associate a file type". The former will not change the .pdf settings, while the latter will.
Yea, you can prioritise which news feed gets to the top. 4 sliders. That's it. Yea, real configurable. I never said it was ie, I even put in the path you can follow to load ie in windows 10 as you can't do it otherwise through tiles or apps.
I'm talking about the interface and options that are under "system" Looks the damn same as the pull down menu on my win10 phone. Why does my desktop need flight mode and the other mobile options?
Damn kids ruining windows. I remember being an active win98 / 2000 (I had dual cpu input on that one), winxp tester. But fuck me how could they let it slide to this totally compromised mess? Yea I blame you, and you can keep your snooty attitude. As I said earlier, using win10 outside the phone, disgusts me physically, as do apps in general as too many of them are wrappers for web sites filled with permission granters they don't need.
Just set Edge up like IE
Woah that would require people to actually spend maybe 10 mins looking and learning how things have just been placed in slightly different locations and read through the settings options. That's not how to review browsers on the internet, you start it up find something isn't in the same place claim the feature is missing and call it trash. Then proceed to post benchmarks which are all but pointless now of days because phones lie and mobile versions are different builds and every desktop unless it's somehow 10 years old is powerful enough and browsers are just fast in general.
I like Chrome, I've used it for years and I like being able to be browsing on my phone, to easily opening up the tabs from the phone on the computer and vice versa. Also all my favorites are in both places and if I add one on the phone it's also on the PC and vice versa. I haven't even opened Internet Explorer on my computer since Windows 10 installed and I've never seen this Edge Y'all are talking about. I thought Edge was a Ford SUV?
i dont use edge anymore because the damn thing keeps on crashing and the favorites list, you can import favorites but you cant export... and i cant translate a selected word as easy as in ie. microsoft makes everything new and more difficult.
I can't launch iTunes with Edge. Been like this for months, I have to copy and paste the page link into another browser and launch from there. Probably going to ditch Edge myself. Can you re-order your favourites list yet? You couldn't a while ago.
Edge was the only browser I could use to stream UltraHD content on Amazon Prime, now some Windows update has hosed it. I'm pretty sure it's an HDMI HDCP issue, but I'm done trying to find workarounds for it.
Dickbags.
Just tried it out, seems pretty fast but not really digging the buttons and stuff,
