Well while I was building my new puter so I could play some Doom 3 while I waited for HL2 I decided I would do more then my normal mods to the case ( airflow & cables ).
I have a 6077b ( I never remember the number correctly ) and I really like it and it has a lot of external bays to play with.
I also have a lot of USB devices and I hate having a hub kinda just floating around the computer. So I picked up one of the Targus 2.0 7 Port Hubs to play with.
That was quickly reduced to parts and the board come out without a problem.
Then I was working on the power for this and I am going to tap the 5v on a plug when I thought why solder ? I went to the shack and got an Adapta-plug extender and an M plug end. Cut the male end of the extender off run the wire and splice it into the 5v & ground on a unused plug end.
Now I had to get a way to mount this in my case. I was looking for a way to mount it so it didnt take up room something else might make better use of. After about a week of futzing around I just decided to di it in a drive bay adapter.
Broke out the dremel, Bondo, JB Wield, sandpaper and Semi Gloss paint and came up with the following in about 2 hours.
and
Sorry I didnt have the camera with me at work when I did all the work. But I started out with a vented grill that was mostly solid. Fill the holes with bondo and sanded smooth. I then traced an out line of the face plate on the drive face and started to dremel to get a very rough fit. Using sanding bits I got a nice mostly fitted hole for teh plate.
I didnt like the hard edge so I mixed up some JB Wield and went to town laying down a nice radiused edge with my finger using the JB Wield. I also use it to glue the USB Plate to the Drive face. Many many peices of sand paper later I get a fairly smooth finish ( not as nice as I would like but its useable ) and lay down some semi gloss and see how much work Ill have to do to get this where I want it.
When I get it all wired in and get the USB cable issues worked out 100% Ill post up some pics of that real quick, but I am off to Orlando for the next few days for a tournament so i'll chech back in, in about a week or so.
-Robert
and
-Robert
