Dead Parrot
- Mar 4, 2013
Connect some kind of brief load like an 1156 auto backup bulb across the terminals. Pb type batteries can have a 'top off' charge higher then the nominal voltage. Doesn't take much draw down to get the battery to revert to the more normal 12~13v. Could be that after years of continuous charging, they have developed a bit of weird chemistry to keep the higher voltage. Despite being in use for over a century, we don't have a full understanding of what goes on in a lead-acid battery.
As long as you are not drawing max UPS VA load, the 7AH batteries should be fine.
