If you seen my other thread, you may already know that I have bought the parts, and they are on their way.
If not, here's what I am upgrading my PC to...
FROM/TO
-PD 820/PD 820 No Change
-Windows XP Pro/ Windows XP Pro No Change
-1.5GB Ram/3.00GB Ram Change
-Radeon x300/ eVGA 7900GT KO Change
-2x80GB HD/ 2x80GB HD No Change
Alright, anyways, the reason I have posted this thread is that the parts are arriving, and I want to know in which order I should install them in. I want to do a complete restore also...
Here's what I was thinking....
Restore with no upgrades installed. Once I am done restoring, and in Windows, I will uninstall the x300 Radeon. I then will shut down the PC. Take out the x300 Radeon and replace it with the 7900GT KO. I will then take out 1.5GB of the ram, and add 3.0GB. I then will power on my PC, and install necessary drivers.
Should I do it the way that is listed above...or no??? Please feel free to post any suggestions.
Thanks In Advance!
FROM/TO
Thanks In Advance!
