Upgrade worth it???
My current PC is: Crooshair V / X6 1090T to 4GHz / 2x R6970 Lighting / 8GB 1600MHz (7-7-7-24).
I bought the 3rd R6970 Lighting in an attempt to eliminate the micro-stuttering in Eyefinity (5040x1050), and I believe that the CPU will not hold 3x R6970 Lighting. (the famous bottleneck)
My question is: is it worth moving to Intel? I saw that the LGA 1155 is highly recommended to limit three GPUs by PCI-E lanes. This was thinking of the I7-3820 (LGA2011) is the price for a good motherboard (3-way croosfire good) will be similar to LGA2011 in Brazil.
Is it worth selling my mobo and upgrade to the i7-3820, I believe that the cost comes to $ 600.00 (- the amount I sell my current mobo).
Will I see a big performance difference at 5040x1050??
Games I play: Battlefield 3 and Elder Scrools V: Skrym.
Remarks:
* My watercooler system compatible with AM3 + / LGA 1155/LGA2011.
* I'm a fan of AMD, but I'm dropping the FX-8150, reviews by the over consumption of energy (300-400 watts scares)
Any comments / help you decide will be welcome.
Thanks!
Remarks:
Thanks!
