- Jul 24, 2021
The thing is you can't even keep the OLED bright because it will burn in the pixels so what's the point? They are making the latest ones brighter but at what cost? Lifespan? Lol it's like over clocking a CPU to the max even though you're frying the core with too much voltage. The heat from the high brightness burns the pixels in OLEDs so it is recommended not to use full brightness also not to have static images on the screen either. Where as the mini led doesn't suffer from any of these handicaps and looks 90% as good as the OLED and that's being generous mostly looks 99% indistinguishable from an OLED in my opinion.Burn in yup, but dim? At least not the TVs. Unless you consider the Samsung S95F doing 2300 nits peak and 440 nits full field to somehow be dim in which case the QN90D should be considered dim too since it doesn't even hit 2300 nits.
