Getting an OCZ vertex 3 which is SATA 3 6.0 g/b. Do I need to get sata 3 cables to take advantage of this? Thx.
BTW: This message comes from Serial ATA site.
9: Does SATA 6Gb/s require different connectors and cables to support the higher
transfer speed?
A9: The same cables and connectors used for current SATA 1.5 and SATA 3.0 Gb/s
implementations can be used to connect SATA 6Gb/s devices, although SATA-IO recommends
quality components be selected to ensure data integrity and robust operation at the faster SATA
6Gb/s transfer rate. Keeping the existing SATA connector form factor enables SATA 6Gb/s to
be designed into the same cost-conscious hardware architectures while minimizing
infrastructure changes.
So I can use existing cables but they recommend "quality components..."? So what is it: do I need to upgrade my cables to the rather expensive SATA 3 ones? (or perhaps the OCZ drive comes with SATA 3 cables?)
transfer speed?
