bench261 said:u gotta tighten the nut while forcing the swivel the other way......mine doesnt sag anymore, it can also be because i broke it in as well
chapichapo said:Hi,
Just got the 2405... It's all good except:
- a bit of sagging to the right (0.2"), although I don't really notice it anymore after a few hours of usage.
- scaling doesn't work very well: with DVI scaling is disabled for any 16/10th resolution and in DSUB scaling is possible but the positioning is terrible (the picture is too far to the right)
Maybe it's my video card?
I have a radeon 9700pro which works very well in DVI 1920x1200 for 2d apps but for recent games the card isn't really smooth at this resolution, which is why I'm rather disappointed scaling doesn't work properly especially with DVI !
chrism said:I don't see how that will help. There is a peg that is directly connected to the swivel mechanism. That is what is in the way. It's what controls the LCD swivelling at each end, but unfortunately it stops the LCD a little bit too soon in the landscape setting. The only chance I can see is constantly pushing down on the left side of the LCD, and hopefully stretch the material a little bit.
chrism said:You should read my previous posts which directly answer both of these points.
adama0 said:I asked this on a video card thread, and got one report from someone who had lots of problems with his MSI AGP 6600GT (same model as mine) at 19200x1200 over DVI -- I wasn't sure if he properly added the res to his settings, though (was a bit hard to understand what he was describing). Think I also saw one positive report with a 6600GT as well. Anyone else using a 6600GT, and if so, did you have to reduce the blanking interval to make it work, any "noise" (what precisely does such noise look like, anyway?), etc.?
My 2405 should arrive tomorrow, but tomorrow is also my last day to return my recently purchased 6600GT, so I'd like to solicit some more reports if there are any to be had.
Thanks,
Adam
EnderW said:I pushed mine all the way down and it clicked in place, now how the hell do I get it back up?
ahh...I couldn't find the button at firstbench261 said:lol, same happen to me when i 1st got my 2005fpw
u press and hold the button and push the panel all the way down and let go
Nah, I can't make m out as it is, unless you put your face right on the screen.ImLazZzy said:The pix pitch is .27 or .258? Do you think a smaller pix pitch would be better?
adama0 said:(what precisely does such noise look like, anyway?)
stevenj said:what's that ???? On my 2405fpw
http://pages.infinit.net/stevenj/
Mcklain said:Ok well got my monitor yesterday.
I tested it last night and everything is going smooth!!
Pics of dell 2405:
This is the stress test @ High quality 1920/1200 with 2x AA and 8x AF= 93 FPS
Mcklain
Maad said:We can't see it on your screenshot
You need to take a photo
If I was going to take a stab at guessing what the problem is, my first guess would be that it is a DVI transmission quality issue.. Lots of people with those problems report lines and weird crap on their screens. Try it with another video card / or cable / or analog VGA
bench261 said:replacement question?
if you ask for a replacement, would they charge you another on ur cc till they get one back?
can you hold one till you decide which one you want as well? i'm asking cuz mine not only came with a sagging problem which i sorta fixed, but came with as dead pixel as well
If the monitor isn't plugged in to anything (except power) and you STILL can see the green line, then it's definitely a problem with the monitor. Call up Dell and have them send you a replacement. You seem to have received a dud!stevenj said:I try without connect the cable to the pc, do auto test = vertical green line was there
I try vga cable = again the same line was there
I try "of course" dvi cable = the same line was there
So if I try without connexion monitor-pc and I saw this vertical green thin line...so the problem come from monitor ??
Riptide_NVN said:bench dead pixels do not always show up right away either - I've had them appear out of noowhere usually within the first couple days of usage. The second dead pixel on mine didn't how up until approx. 14-20 hours of operation had passed.
Mcklain said:I was quite impressed myself.
Before with the 2005 I was playing @ 1680/1050 with 6x AA and 16x AF and in the stress test I was getting about 95 FPS.
Playing now @ 1920/1200 with 2x AA and 8x AF gives me about the same FPS. Plus running at that resolution AA is not that important cause the res is so high.
So the bottom line is that I am not loosing any performance at all playing at a higher res wich was one of my main concerns before pushasing this panel.
Mcklain
chrism said:OK, 2 of my problems with the 2405FPW have been resolved.
1) If you try turning the LCD on the swivel when the stand is not all the way extended, you get that plastic rubbing sound. So just make sure the stand is all the way extended.
2) If you set your desktop resolution to 1600x1200, you can change the scaling. When you go back to 1920x1200 the setting is remembered (even though you can't tell from the onscreen menu).
Still having the sagging to the right problem. This appears to be structural with the stand, not related to the weight of the LCD. There's a lock on the swivel in the stand that prevents the LCD from turning too far left. I don't think adjusting the screw will make any difference because the lock is built right into the panel. Unfortunately, it stops a little to short, leading to the sagging. You can push down on the left side to straighten it, but it doesn't seem to stay that way. I'll try pushing down regularly to wear it in, or maybe hanging something heavy on the left side.
chrism said:Hate to break it to you, but there's a lot bigger difference between 6xAA and 2xAA and the small resolution bump you got.
Mcklain said:Well I aint seeing a big difference on this panel.
Have you tried it?
Mcklain
chrism said:I haven't, because I don't have the game. However, it's difficult to believe that a 30% increase in resolution is better than 3X the FSAA and 2X the AF. I'd say that's a lousy trade. I think you're just in awe of the size of the screen.
Of course, running the game at a lower res on an LCD leaves a lot to be desired, so you really don't have much of a choice but to take the quality hit.
bench261 said:wats the diff between a dead pixel and subpixel? is a dead one completely burnt out? congrats on ur flaw free panel...heres some advice never check again once ur satisfied
kilmar said:I have the game, and the 30% increase in resolution is beautiful. I play HL2 and CS:S quite often (2+ hours a day) and there is no trade-off by lowering the AA when playing in 1920x1200 (I keep AF at 16x).
at 1920x1200, there's very little difference between 4xAA and 2xAA. Granted, that I am absolutely in awe of the screen, but I have every reason to be as it is superior to the 2005FPW in every way.
If we were to poll people to choose a or b, I bet more people would choose b:
a) 20.1" Widescreen @ 1680x1050 with 4xAA 16xAF
b) 24" Widescreen @ 1920x1200 with 2xAA 8xAF
There is also another imperfection out there that I've seen on more than one monitor. My 2000FP had one and so does this 2405FPW. It is a pixel, or at least it sure looks the size/shape of one and is in the right spot, but it is gray in color and shows up best against a white background. Looks like a speck of dust or imperfection in the coating but it's not - it's definitely underneath the coating.bench261 said:wats the diff between a dead pixel and subpixel? is a dead one completely burnt out? congrats on ur flaw free panel...heres some advice never check again once ur satisfied
