I'm having an issue getting my winbox to see the shared folder so I can use hfm to monitor the ubuntu setup.
By machine name or ip address? I gave up on machine name a while ago.
As in are you using it...because we said don't....
slaughters machines performance over 16 cores... or 24 intel threads...
node interleaving off numa on.... set any power save features to max performance... and use da kraken... and just say no to bfs...
IIRC BFS is only good for upto 24 threads, Even the guy who made it says so, it you have 8c/16t chips you are rocking 32threads. In which case its best to stick with the regular scheduler
OK now just need to figure out how to uninstall BFS ;-)
I'm having trouble untar thekraken. it says its not in gzip format
firedfly@PxeServer:~$ md5sum thekraken-0.6.tar.gz
5a3a47e6dc095cac47e8e79f4db04ac4 thekraken-0.6.tar.gz
file thekraken-0.6.tar.gz
wget http://darkswarm.org/thekraken-0.6.tar.gz
$ wget http://darkswarm.org/thekraken-0.6.tar.gz
--2012-03-11 15:08:03-- http://darkswarm.org/thekraken-0.6.tar.gz
Resolving darkswarm.org... 85.11.66.60
Connecting to darkswarm.org|85.11.66.60|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 18643 (18K) [application/x-gzip]
Saving to: “thekraken-0.6.tar.gz”
100%[======================================>] 18,643 48.6K/s in 0.4s
2012-03-11 15:08:04 (48.6 KB/s) - “thekraken-0.6.tar.gz” saved [18643/18643]
http://code.google.com/p/hfm-net/logo?cct=1286848347
"yourfavoritetexteditor" ~/.local/share/applications/hfm.desktop
[Desktop Entry]
Version=1.0
Name=HFM.NET
GenericName=HFM.NET
Comment=HFM.NET
Exec=gksudo mono /home/"username"/hfm/HFM.exe
Terminal=false
X-MultipleArgs=false
Icon=/home/"username"/hfm/logo.png
Type=Application
Categories=Network;
MimeType=text/html;
StartupNotify=true
Three thoughts....
1. How is this still not stickied?
3. Would be good if we could find a way to script Ubuntu Server samba setup. Assume this guide is followed so F@H is in /home/username/fah/ That would make HFM setup much easier. Ubuntu server is just much lighter than desktop from an installation size perspective.
2. Wonder if 12.04 will be faster.
Any volunteers for testing?
