DooKey
- Apr 25, 2001
Just noticed a big slowdown with one of my Linux machines. I believe one of the recent updates effects how well things fold. Has anyone noticed this?
kernel revved... knocked tears wrapper off... try and re installing kraken...
or, you are running a non-BFS kernel after the update. Try typing uname -r and see what it returns. If it doesn't end in -ck, then that is what happened. If so, go to step #3 - http://hardforum.com/showpost.php?p=1037125472&postcount=3
It mainly crashes after 90 mins or so of foldingDoes it crash early in the unit, or when it goes to upload? I was having an issue I thought was the overclock, would BSOD Windows when the VM went to upload.
H.
was fine previously.
Under windows it goes and goes but VM Ubuntu 10.10 is being painful.
My machine is fairly new and this is the first kind of issues with folding ive had.
Temps are fine(high 60's) / voltage is fine (1.38) / modest overclock at the moment 4600 (2600K)
not sure if theres something specific im missing - or if im even in the correct thread
will give it a try as i swallow my pride
4400mhz with a H70 seems painful
4.4GHz is the average for i7-2600K. Means yours is better than about half the chips out there.
That seems so low based on what you see on forums and signatures across the enthusiast circle, may I ask where the source of that average stems from?
I'm 2 for 2 on 2600k's that fold at 4.7ghz at the upper end (1.38) of the normal voltage range and I consider my chips low clockers compared to most others on the board. I'm not questioning you info, I'm just shocked it could be that low.
I know, but consider it a troubleshooting step - if it stabalizes, you know you need to tweak the overclock to get it stable at a higher clock, if it doesn't, then it's probably not the O/C and there is something else you need to look at.
H.
The only tool that works well for this is i7z - http://code.google.com/p/i7z/
I need some HELP. Trying to get Ubuntu 10.10 installed. It crashes indicating that there is a corruption in the CPU or the CPU is not supported. I am currently running an SR-2 w/2x L5640's (ES). This is a similar configuration to more than a few members of the [H]orde.
- Is there something special that needs to be done as part of the install? I am at stock clocks and it still continues to crash with the error messages.
- Is there a different version of Ubuntu that I should try?
- I've tried unetbootin as well as direct from a CD with no joy
musky, huge thanks for the guide.
I am currently folding on a 6901 (unfortunately) with the kraken successfully running and FAH successfully installed (I think)
I only understood about 50% of what I did, but your guide made it easy. Now I just need to work on sharing this PC's drives on the network and getting a WHS VM running properly.
+props
I setup over the weekend as well, nothing like blindly typing in CLI commands that you know nothing of!
Or even better, just cutting and pasting the whole damn line from Musky's guide using Ctrl-shift-v
Can anyone confirm this post? If not, I will try it next week anyway.
http://foldingforum.org/viewtopic.php?f=44&t=18818
I bet the difference is purely due to Wu variation. He sounds like a noob.Let us know what you find!
If its all kernal though, shouldn't you be able to backport that to current installs for evaluation?
Missing step 9 on Basic Ubuntu Desktop Install (http://hardforum.com/showpost.php?p=1037125470&postcount=2) ..
So, when perform step 10:
./fah6 -configonly
received error message:
bash: ./fah6: cannot execute binary file
chmod 755 fah6
-rwxr-xr-x 1 dave dave 314840 2011-02-23 17:12 fah6
