Trying to clone a dying drive
The laptop drive went tits up, showing a sizable amount of reallocated sectors in SMART.
It has gotten to a point where it can boot to windows fine, but you cannot use Windows Explorer to look at the drive or even open folders, as the drive would click furiously and explorer will automatically force quit and restart.
I had Acronis TrueImage installed on the laptop already, so I plugged in an external usb drive, set the program to ignore read errors and proceeded to image the drive. The imaging had gone smooth up to a certain point (95% done) where the program would just hang without doing anything and no drive activity (unless I actively tried to open applications/files), it would not budge, no matter how long I waited but it allowed me to cancel the operation.
I tried another way, using a Knoppix BootCD to just try to copy the files via drag&drop since I dont have prior experience with linux, I dont know of any other way to recover files. Unfortunately, at random times, the OS would either refuse to read the files, hang while reading/copying the files, or just completely hard lock the whole computer.
Then I hooked up the laptop drive into my desktop computer, Acronis TrueImage failed with the same issue and DriveImageXML would just hang on detecting drives.
Is there any other way of imaging the drive?
