Aren't those the MBs that just hit the marketplace?Hippie - You will have to wait for the Ivy Bridge X79 which will give you 10, count em 10 6Gb/s SATA ports.
Who the hell cares. When you saturate that many ports on a CPU controlled software based solution you are gonna never meet the bandwidth potential.
I will take hardware add in card any day over software.
Jibberish......
And the x79 chipset only gives you 2 SATA 6Gbps ports..
With that being said, 10x SSDs doing 550MB/s reads = 5.5GB/s which will eat a lot of controller/ PCIe bandwidth. That is why Intel and a lot of the storage guys say that PCIe generations are not keeping up with bandwidth needs of modern devices.
And to other posters talking about 100s drives on CPU controllers sure but that is not Windows and its not Intel ich software because they don't support hundreds of drives so don't use that comparison.
Seriously does anyone use that much bandwidth in their home? Unless your running a fiber channel or iscsi with bonded 10gbps nics a 10 disc raid 0 is not gonna feel any different loading software than a single 6g ssd.
Honestly its nuts. But it would be nice. And to other posters talking about 100s drives on CPU controllers sure but that is not Windows and its not Intel ich software because they don't support hundreds of drives so don't use that comparison.
Users who rebuild large databases and do lots of video editing can easily utilize those data transfer rates.
I don't know why it wouldn't be. Having the ability to RAID0 two or more SSDs and enabling TRIM would help a lot of end-users. No, it's not the majority of the market, hardly, but the technology is exciting and will be very useful to a select group which requires high speed and endurance over time, which, without TRIM, is not possible.Given the transport infrastructure is in place.
Not necessarily, many individuals do not have hardware RAID setups with SSDs, but do use the Intel fakeRAID controller to add SSDs or HDDs in RAID0.And its probably very rare and people like that are not waiting on 10 sata ports from Intel. They already use Areca, LSI, Adaptec, etc....
you're saying spinners in raid0 are unstable yet you welcome doing the same thing with drives that are on a clock the second you start writing to them?Many times, a single SSD is simply not enough, and very large HDD RAID arrays in RAID0, while fast, are highly unstable, regardless of the controller or RAID type being used.
wtf?
and 10 HDs in raid10 are going to read at the same speed as 10 discs in raid0 so why would i run raid0 at all?
raid0 is just retarded anyone who runs it for anything other than "lol look at the numbers" is a fool.
Not sure why you're all arguing over something that you'd all ultimately agee is a positive development, and a long overdue one... This thread took the off ramp after about a dozen posts and then hitchhiked it's way to nonsenseville.
nobody runs a database, of any size, on raid0. further, if the database is large enough that it would actually require the space differential between a raid0 and raid10 then said database is going to be broken down into multiple parts anyway and run clustered across multiple servers and multiple disk arrays.
on another point RE size and raid10 vs raid0 if you're into that type of size requirements using modern spinners then you're into areas where backups take a really long time. likely you're replicating in real time to a dedicated replication server, dropping a snapshot, and backing up off that. which means you're delta between live changes and most recent backup are often in the 12-24 hours time frames or more which is significant so there goes your daily backup idea for your 10 disk raid 0.
Where did I ever say that RAID0 was ok in the "industry"? By which I believe you mean an enterprise-grade situation.obviously you dont actually do any work in the industry beyond maybe low end tech support.
Speak for yourself. You keep talking about things I never said or stated.you have no idea what you're talking about is what i'm getting at.
Only those who can't handle it are be afraid to use it. -hint-raid0 is for fools.
Real mature, grow up.yes, now that we're on the same page want to hug it out?
No, the X79 chipset with a sandy-bridge E CPU gives you 2. The X79 With the Ivy Bridge CPU will have 10.
http://www.techpowerup.com/146582/Gigabyte-X79-UD3-LGA2011-Motherboard-First-Shot.html
http://vr-zone.com/articles/x79-to-have-10-sata-ports-after-all/13317.html
Yep.You're seriously linking articles from may? You realize that the rumoured specs of this PCH has changed like a billion times since then, right?
its the same bus though. the SAN heads from EMC/Netapp etc what do you think they're using for their motherboard interconnects? Here is a hint its PCI-E. Also the low end EMC clariions run windows, or at least they did as of the CX3. 480 disks was the max supported.
Yep.
mwroobel is a little behind the times.![]()
Hey, I started the thread4 of the sata3 connections are coming from the pch, many of the x79 boards also have an addition controller (or more than 1, asmedia or some other) which allows for up to 10.
Y...extra controllers do not add SATA3 ports to the PCH, and you cannot RAID drives running off the PCH with drives running off a add-in controller... Well, with software ofc, but not with the Intel Matrix RAID Storage or whatever they've decided to call it this time...
My mind reading hat musta been disabled that day. LOL!. Also, I looked back in the beginning of the thread, I mistyped, I wrote: ...Hippie - You will have to wait for the Ivy Bridge X79 which will give you 10, count em 10 6Gb/s SATA ports. ... and I meant to write ...Hippie - You will have to wait for the Ivy Bridge X89 which will give you 10, count em 10 6Gb/s SATA ports.
I'm pretty sure the X79 boards were supposed to have more SATA6 ports but Intel ran into a bug?
Can someone shed a little more light on this?
