Nomikal said:any alternative links?
Skirrow said:Why do i think its a console port?, well The gfx are very colourful and the whole level has that plastic laminated look that Perfect Dark Zero had. I know thats not enough to convince anyone of a port but it just looks and FEELS like a console game to me. More specifically an XBOX 360 port. I dont know how to explain it, but when i play a game that has been ported from a console to a pc, there is a different 'feel' to it. Like you can tell it has been ported. The only game i played that i couldnt tell was Area 51. That was a good one.
Anyway back to Timeshift. The size of the level itself also leads me to believe it was designed for a console, being small enough to fit into limited memory. Still, even the 360 can handle levels a hell of a lot bigger.
Gamespot say to 'check out a full playable level of timeshift'. If thats an entire level then i'm gonna have the entire game cracked in just over 2 hours. I suspect it isnt a full level and just a 'chapter' of the level.
Now i'm not knocking the game just because, to me, it feels like a console port. I was just saying that in my opinion it definitely IS a port.
I could be wrong. They could have ported the PC version to the 360. Who knows.
You read my mind.FalseGod said:I hope there is a torrent posted by the time I get home from work tonight.![]()
Tiny said:Fair enough on the console port issue. But I think we have been seeing more of the 'plastic' feel since Doom3. I don't know what engine Timeshift is using, but any game that uses the same engine as the Doom3 engine is...to me....crap. I can't stand the 'plastic' feel myself.
And as far as Timeshift goes, I read the same thing...that this demo was a single level of the game and is was super short. So it is off of my computer already.
From GameSpot. It worked for me.AndoOKC1 said:ive downloaded this 3 times from 3 different websites...and i keep getting the same error
Error Code: -6001
PLease do the following:
-Close any running programs
-Empty your temp folder
-Check your Internet Connection (Internet-based Setups)
Then try to run the Setup again
...i did all that and it just wont work...anyone else getting these probs?
Liquid Spark said:From GameSpot. It worked for me.
"Got it. The solution was posted in a thread below that i didn't previously see. Sorry. Here ya go. It worked for me.
If you get an InstallShield error code -6001 during setup, try simply deleting the following folder from your computer and attempt to run the installer again:
C:\Program Files\Common Files\InstallShield\Professional\RunTime\0701
mi1stormilst said:The best way to tell if it is a console port in my opinion is the menu system and the graphic options, they are usually over simplified and in some cases you can't even use your MOUSE on the damn menus properly. NFSU or NFSU2, or just about ANY Star Wars game...sigh.
qbert3 said:I didnt like it ;/ i like hl2/counterstrike but hate unreal tournament type games. that game just doesnt "feel" right
