In terms of output there are 2x dual-link DVI outputs, one HDMI and one full size DisplayPort on board. This video card does support NV Surround from a single-video card. This means we can run our triple display setup from this one video card.
Is it like AMD where one must be DP if you run more than 2?
Or can you use HDMI/DVI/DVI?
Actually you can use all 4 ports at once if you want.
Why don't you just read this guide???
http:///optimize/guides/how-to-correctly-configure-geforce-gtx-680-surround/#2
Link flail!
Well.. g e f o r c e.com is filtered out on [H] for some reason. So it broke the link.
I have a 7680x1600 setup and have been considering that using a three or four-way SLI with the 680s, but I think that the 2GB memory is going to be a bottleneck for that setup. So, I guess I will end up using three or four 7970s instead since they have twice the memory to work with...
Input is appreciated....
50% more, but yea you'll probably want that 3gb for 7680x1600.
Rift at 8100x1600 used to use up about 2.3GB of vram on my 580s. I came to the same conclusion as you...if I'm going to upgrade, I'm either going to have to wait for some 3GB 680s or go AMD for the first time in lots of years...
with amd it only takes 1-2 sec..
another useless card from NVIDIA.. (for multi monitor users)
Wow, I'm sure that's not an issue they can fix in a driver package...![]()
