Imitation is the most sincere form of flattery, huh Necere?
Didn't LianLi make those cases for Ncase?
Lian Li manufactures the NCASE M1 as well as the Dan A4 as rfarmer points out. However, NCASE owns the design.Didn't LianLi make those cases for Ncase?
Agreed.Nwegg's mobile app says 9/22 for me.
Still doesn't stop me from refreshing the product page a couple times a day...
Fuck overly crammed ITX cases with pcie risers chasing the volume autism that require AIOs or only support anemic air coolers. Both worse and/or noisier than a good tower heatsink. The best fan right now is 120mm too, happy coincidence.
I have an NH-D15S with the Chromax covers which puts it at 165mm. Very interested to see if it fits.
I've loved the look of this case since it debuted at Computex. I was having a hard time deciding between the two colors but ended up pre-ordering silver. I have an NH-D15S with the Chromax covers which puts it at 165mm. Very interested to see if it fits.
Some reviews I've found so far
TweakTown
TechPowerUp
bit-tech
eTeknix
Any word when the ASUS Strix DTX board is shipping ?
Kenny
It may help but it may not. I'll be interested to hear the results.
I'm in an NZXT h210 which is similar in size to the TU150 but supports more cooling options; I'm running a 260mm AIO on the 7700k@4.9 in the front inhaling air, a 120mm AIO on the 2080TI exhaling air in the back, and a 140mm fan exhaling in the top. CPU never gets over 67C and the GPU never goes over 68C. I'm not even running heatsinks on the VRAM and the modules are just warm to the touch with the fan blowing across them (NZXT G12 AIO Bracket).
I was originally considering one of the smaller Sligers but the cooling support is a bit low IMO. Are you planning on selling the Cerebus?
My only knock would be intakes don't appear filtered. We can never win against dust build up, but I prefer to at least put up a fight.
I would purchase one if it had a vented side panel instead of glass.
I could see this being the 'BitFenix Prodigy' of entry 'premium-level' mini-itx PC cases. I am curious how well a Noctua NH-U12A with 2 Noctua 120mm Sterrox fans (1 front, 1 back) does with a 3900X / i9 9900K and 2080 TI setup.
Also I heard it has micro usb c latest rev in the front io to match up with the Asus ROG Strix X570-I Gaming board which is also DTX.
I don't like that it is SFX PSU only ..I think the top area is wasted with the recess for the handle, not vented or accommodating a fan .. so extra volume like a tophat but no real benefit.
NZXT is better for liquid cooling(Which I don't want), but the TU150 is better for GPU Air cooling.
The problem with air cooling in the standard form factor ITX cases like the NZXT H210, is that the GPU is basically crammed against the PSU shroud choking off it's fresh air supply.
How is the cpu temp doing? I am considering this case, but I would really have preferred a mesh intake for that front fan to supply the air to the cpu cooler.Got a 3080 recently so thought I'd give an update for anyone interested in this case / card combo. I previously had an EVGA 2070 Super with 2x Corsair LL120 fans in the bottom of the case.
The 3080 XC3 Ultra is a bit taller than the 2070 was. As a result it was extremely close to the bottoms fans - like a piece of notebook paper of space - practically touching. In BFV the card was running around 82C. It seemed a bit high compared to what I was reading for folks with the same card. I ended up grabbing a pair of Noctua NF-A12x15 fans in throwing them in the bottom. Card hasn't gone above 72C since the swap. The extra room to breathing room seems to be helping I guess.
The XC3 and Noctua's are very quiet though - very happy with both the performance and acoustics of both
