Thoughts on first gen E5-2670
Discussion in 'Intel Processors' started by davewolfs, Jan 9, 2016.
  1. davewolfs
    davewolfs Limp Gawd
    335
    Nov 7, 2006
    So I've been using an i7-920 for many years now and lately the machine just hasn't been stable.
    I want to upgrade but I feel like Skylake isn't well suited as I could use more than 4 cores (I'll use AWS sometimes for certain tasks).
    Right now there is a fire sale on these E5-2670 chips. They can be obtained for around $90 a pop, memory is dirt cheap as well. Basically I'm debating if it makes sense to invest in Sandybridge until we see some new processors eg Skylake-E or the E5 V4s.
    Any thoughts on this? Am I better off just going with X99 or does this make sense?
  2. arestavo
    arestavo [H]ard|Gawd
    1,354
    Mar 25, 2013
    If you are on a budget then you can't go wrong with Sandybridge. Some games that are heavily limited by a single thread will not perform as well due to the lower boost clock, and hopefully with DX12 that issue will go extinct.
    If money is no object then go with a X99 with a 5930K or 5960X and overclock - the overclock alone, disregarding the architectural improvements, will make it much better than the 2670 V1 (which benches like a 3930K in the 3DMark11 benchmark test)
  3. davewolfs
    davewolfs Limp Gawd
    335
    Nov 7, 2006
    Don't really play games but hey you never know.
    SB just seems so damn cheap. I mean my up front cost is 450 (2xCPU, 1 Dual Board and 32GB Ram). Overclocking isn't really an option. I'd likely go with the E5 58xx equivalent which uses the C612 chipset along with ECC memory. Really looking for stability.
  4. arestavo
    1,354
    Mar 25, 2013
    So you are more of a workstation user that will be using multithreaded applications?
    Yeah, it is a no brainer. 2X E5-2670s will beat the snot out of a single 5960X, even if that 5960X is over clocked like a raped ape.
    As for the equivalent on the server side, obviously the 2670 V1 won't be nearly as fast. But the COSTS! My god man, it's excessive going for the same thing compared to what you can get with the 2670 V1 at $90 to $110 per CPU (compared with $2500 or more per CPU).
    Adidas4275 likes this.
  5. arestavo
    1,354
    Mar 25, 2013
    Also, the 2670 V1 supports ECC memory. Just get a board that does as well.
  6. davewolfs
    davewolfs Limp Gawd
    335
    Nov 7, 2006
    Correct this is purely workstation
  7. arestavo
    1,354
    Mar 25, 2013
    For a workstation user coming from an i7 920, you will be extremely happy with a 2P E5 2670V1 system. There is no doubt about that - the difference will be rather, well, large.
    If you want the best, and have very (VERY) deep pockets, the equivalent on a C612 (or if you wait an unknown amount of time for the Skylake-E) will be better performance.
    Coming from an i7 920? Just go with that 2P Sandy and pocket all that extra money for a vacation. You'll be just as glad you did. Oh, and you can splurge on a really nice SSD (or one of those PCIE card SSDs) if you don't already have one with those savings, and experience even better workstation performance.
  8. davewolfs
    davewolfs Limp Gawd
    335
    Nov 7, 2006
    No kidding for the C612 equivalent. To get reasonable performance in an 8 core chip you are looking at minimum $1000 per CPU.
    Just need to figure out what PSU now.
  9. arestavo
    1,354
    Mar 25, 2013
    If you go 2P, you'll want one with two 12V CPU cables - but I'm sure you knew that.
    You can get consumer grade PSUs, even platinum rated, that have two. Usually they are higher wattage. I've used a http://www.newegg.com/Product/Product.aspx?Item=N82E16817121089 back when I had a 2P AMD system, and it worked wonderfully - still use that same PSU in my desktop now.
    EDIT: FSP also makes good power supplies and they have good warranties on them (7 years!) - http://www.newegg.com/Product/Product.aspx?Item=N82E16817104192 should work nicely, but may be more than what you want/need. The 850W model looks to also have two 12V cables.
  10. davewolfs
    davewolfs Limp Gawd
    335
    Nov 7, 2006
    Was actually considering the Corsair AXi series. Not sure if it makes more sense to get 860 or 1200.
  11. Bill1024
    Bill1024 Gawd
    1,005
    Apr 26, 2013
    I am running a E5-2670 on an Asus Sabertooth x79 board.
    Works great for crunching BOINC primegrid
    Waiting for the IVYbridge xeons to fall farther in price, I want a 12 core CPU.
  12. ToddW2
    ToddW2 2[H]4U
    4,029
    Nov 8, 2004
    You can get the other cable for modular seasonic and others that don't come with it...
  13. Shumph
    Shumph Limp Gawd
    396
    Nov 29, 2004
    I am running a 2p e5-2670 machine with 2x gtx 980ti with the evga g2 850 psu.
    With both processors and both gpu maxed out I am drawing 700w max at the wall, so an 850 psu should be fine.
  14. primetime
    primetime [H]ardness Supreme
    5,061
    Aug 17, 2005
    put some pics of that...sounds like a bad ass workstation:D
  15. geok1ng
    geok1ng [H]ard|Gawd
    2,004
    Oct 28, 2007
    E5-2670, while 8c/16Ht, are not OCable. so you should consider going 2p with them if that tickles you.
    In your position i would keep the mobo and upgrade to a Xeon 1366, which are overcloable on most x58 mobos and can be found cheaper. From the X5650 to the x5690 , they all reach around 4.2GHz at a lower voltage than your 920.
    i found a direct comparison between 2p systems running E5-2670s and x5680s without overclock, For some task they are equal, for others they are up to 25% faster than X5690s.
    I run dual X5675 on EVGA SR2, and price wise, 2p G34 opterons mobo are (much)cheaper that 2p LGA2011 mobos, but cooling hardware LGA2011 is easier to find. personally, if i needed a build for many slow cores, i would go 4p G34, which are cheap and can be overclocked.
  16. Bill1024
    Bill1024 Gawd
    1,005
    Apr 26, 2013
    You can get a 2P AMD board and two 12 core Operon 6172 with 2 heatsinks 75$ shipped lower 48 USA.
    Uses a standard PSU
    http://hardforum.com/showthread.php?t=1886166
    I just ordered 2 xeon e5-2670 and a 2p board for them.
    For BOINC primegrid the xeons (Sandy-bridge or better) rock, for WCG the AMD hold their own.
    AMD 4P boards are still expensive, The ones for 100+ do not use a standard PSU
    I have two 4P AMD one socket G34 and one socket F, Two dual xeon e5620, one dual x5660, four single overclocked x5660 systems and the one 1P e5-2670.
    Keep in mind win7 can only see two processors, so you have to use a win server OS or Linux
  17. davewolfs
    davewolfs Limp Gawd
    335
    Nov 7, 2006
    How much did you get your 2P board cost and what did you get?
  18. Bill1024
    Bill1024 Gawd
    1,005
    Apr 26, 2013
    This is the 2P socket 2011 board. Bord came in today, waiting on the two e5-2670 to come.
    Paid 200$ for the two CPUs.
    I had a 50$ gift cert. for newegg so I used that to cut the cost. 279$
    Not many cheap 2P 2011 out there.
    ASRock EP2C602
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157352
  19. Saki630
    Saki630 Limp Gawd
    300
    Aug 10, 2006
  20. Starbomba
    Starbomba Limp Gawd
    252
    Aug 24, 2014
    Coming from a quasi-server usage standpoint, i find a LOT of use for the extra cores. Even a Q19D Xeon, with its low speed but 8 cores, is still quite a match for my X5650 at stock speeds.
    IMO, i would test first with a X56xx 1366 CPU. My X5650 did awesomely on anything it ran, way better than any 115x CPU, and even my old W3530. Plus, you save the RAM/Mobo updates as it is a ready upgrade for well under $100. Plus, it can be OCed, unlike the E5-2600 Xeons which are fully locked.
    If it does not work, i find X79 to still have a lot of life, as expected of any "big socket" platforms. Hell, if you ever need more muscle than 8 cores, you can get a E5 2695 v2 or higher, and get 12 cores for relatively cheap (compared to newer Haswell-E equivalents). Plus, server boards for Ivy-E for dual socket are cheap nowadays, to get up to 24 cores.
    Only get Haswell-E if you need way more power than that, core-wise. I really see no benefit of C60X chipsets over C61X chipsets (or X79 to X99). Maybe Intel's next chipset refresh may bring more improvements (like the Z170 for Skylake) but it is a long way until then.
  21. systemvipers
    systemvipers Limp Gawd
    283
    Jul 22, 2013
    WAHOOOOOOOOOOO, got the chip yesterday, had to work last night but spent the early evening installing an OS on the system
    today i poped in hte chip and this is what i got..... i am so excited, now i need a good video card, nothing spectacular but something
    like a gtx 770 or gtx780 depending on price
    check it out....
    click it...
    Intel Xeon E5 2670 @ 3001.45 MHz
    Dump 4112532 [ba7c9n] - Submitted by systemviper - 2016-03-05 17:09:15
    [​IMG]
    What a steal, i was saving this system for something and now i got an 8banger for cheep, whaooooo
  22. arestavo
    1,354
    Mar 25, 2013
    If you can, OC that RAM and it will help out a good deal if you play games like Rise of the Tomb Raider and (especially) Fallout 4.
    And yeah, it is a super bargain for what you get!
  23. systemvipers
    283
    Jul 22, 2013
    thanks for the advice, I have to work tonight so today is to just get it up and running and i will spend the next week fine tuning it and installing software....
    The ram is rated for 1866 C9 so i will try to get that out of it. I am just so excited, i sold my 4930k a while ago and put this in the attic and now
    it's going to get revived as my main work station, I do some programming, creative and video so having the extra cores is a monster find.
    Plus it's just a newer chip, i think i will be using this for a long while now... lol
    Wow seems like you have a nice rig in your sig! Top Notch!
  24. BadSeed
    BadSeed n00bie
    6
    Mar 9, 2016
    OH MAN. I'm so stoked I found this thread as I am in the process of doing one of these builds for a dedicated Premiere Pro render machine for 4k video. Also looking hard at the EP2C602 as the Asus board is mind numbingly expensive and tough to find to boot.
    I'm planning on loading 4 SSDs in this build. Has anyone utilized the Marvell controller? I've had stability issues with them in the past.
  25. arestavo
    1,354
    Mar 25, 2013
    Typically a Marvell controller, such as the one in my X79 Dark, is absolute garbage when it comes to even utilizing a single SSD due to strangled throughput performance.
  26. BadSeed
    BadSeed n00bie
    6
    Mar 9, 2016
    Yeah, even the one on my EVGA z170 Classy board is pretty bad. Need an alternative to getting these drives in here....PCIE adapter? Plenty of lanes to work with...
  27. BadSeed
    BadSeed n00bie
    6
    Mar 9, 2016
    Yikes, looks like all the PCIE Raid card options are all using Marvell controllers anyway. Really want to move to an all SSD setup but its looking like this might not be the platform for me. Any suggestions on how to get the most from 2x Samsung 850 Pros in Raid0?
  28. arestavo
    1,354
    Mar 25, 2013
    If you don't have Intel SATA ports on your board it might get expensive.
    I know that for Adaptec their 7805 and newer controllers were designed to be used with SSDs. I'm certain other discrete RAID card manufacturers have similar models.
  29. Stereodude
    Stereodude 2[H]4U
    3,302
    Oct 20, 2000
    I did this:
    Dual Xeon E5-2600 v2 socket 16 DIMM Motherboard LGA2011 - $175
    plus two of these:
    Intel Xeon E5-2670 SR0KX 2.6GHz (3.3GHz Turbo) 20MB L3 Cache LGA2011 115W Eight-Core - $65 each
    Shipping was about $25.
    I got 8 8gB sticks of PC3-12800R ECC DDR3 RAM on eBay for $15 a piece and I'm off to the races. This is a good option if you're not looking for 1600MHz stuff: 64GB (8x8GB) PC3L-10600R 2RX4 DDR3-1333MHz ECC REG Server Memory NT8C72C4NG0NL-CG Nanya ~$10 a stick.
    OEM XS / kalleyomalley on eBay sells the associated genuine Intel pieces to go around that motherboard in new bulk packaging and accepts rather low offers. Like this chassis / enclosure / power supply, passive heatsinks, I/O Shield, iKVM module, and the ducting for it. You should be able to get the chassis for $115-120, heatsinks for $5-10, iKVM module for $20, the ducting for $10, I/O shield for ~$5.
    They have other Intel chassis too if that one doesn't strike your fancy. One with different power supply wattages, ones with 3.5" or 2.5" hot swap bays, redundant power supplies, etc. Shipping combines too. I paid $36 total to ship a chassis, 2 heatsinks, the ductwork, and I/O shield halfway across the country. I didn't know they sold the iKVM module when I ordered or I would have thrown that in too.
    ps: I can't take credit for the OEM XS eBay find. Someone posted it up at STH over last weekend.
  30. Stereodude
    Stereodude 2[H]4U
    3,302
    Oct 20, 2000
    It all depends what you want to do. Are you trying to boot from it, or what? An LSI based SAS RAID controller is probably your best bet if you want real HW RAID. The cards will be PCIe 2.0 8x . If you just want to hang a bunch of drives on your system, but don't want to be limited to 3Gbps, get an SAS HBA, like an LSI 9211-8i based solution. You can crossflash a Dell PERC H200 or H310 card into an LSI 9211-8i. You can get a H310 for ~$54 on eBay (they were $49 the other day).
  31. BadSeed
    BadSeed n00bie
    6
    Mar 9, 2016
    One of the mods at another forum put me on the LSI 9265 8i kit...snagged one used on ebay for $170ish. Raid0 seq i/o speeds look great in a review. Just waiting on the Asrock board and that raid card. Going in a Phanteks Enthoo Pro and I think I'm all set. Super stoked for this build...4k video is a beast to work with...until now.
  32. Adidas4275
    Adidas4275 [H]ardness Supreme
    5,851
    Mar 11, 2006
    i just went from a 3930k to E5 2670 v1
    video encoding is 20-30% faster with h264 and i dont see any noticeable difference in gaming performance
    I bought 2 of the CPUs thinking I might go 2P or buy another motherboard and run another system for Plex server.... :)
    Great value for awesome performance
    oh and runs cooler than the 3930k
  33. systemvipers
    283
    Jul 22, 2013
    Keep us posted on how that board works out, seems to be a nice solution but the reviews all talk about bios issues.
    thanks in advance!
  34. Bill1024
    Bill1024 Gawd
    1,005
    Apr 26, 2013
    So far so good, just wrapping up a 3 day BOINC primegrid challenge, 16 cores @ 100% load 24/7 and other times I am running BOINC WCG @ 100% load 24/7
    Runs great. No problems. Running the BIOS that it came, not sure if it is the newest or not.
    One issue was I have a GTX960 onboard and had a hell of a time with Linux and the GPU, no problem with a GTX 660Ti.
    So I installed Windows Vista business OS someone gave me, that and an old spinner HD. Makes me love Win7 with a SSD!!!!
    Bit I am very happy with it and plan on building another in the future. Just hope the xeon V2 series drop in price before then.
  35. Beaflag VonRathburg
    Beaflag VonRathburg Limp Gawd
    369
    Aug 3, 2015
    Look at the dates on the reviews.
  36. systemvipers
    283
    Jul 22, 2013
    :sour: lol you got me there, 2014, I would think they are doing better by now, IS there any cheaper boards that can be picked up on Ebay that will run the 2p with the E5-2670
    although I should just bite the bullet and save.... I have the case already, just need the board and chips...
    Figure 150 for the 2 E5-2670's, so just need a board.
    I have been thinking about building a Plex server, but i need to understand more about it, but also will use it for rendering, programming and some creative that i do, After Effects, Flash and Video.....
    But now that i have the Gene up and running i have time to wait and do it right.
    thanks
  37. Stereodude
    Stereodude 2[H]4U
    3,302
    Oct 20, 2000
    Did you read post #29? I provided a link to CPUs for $65 each and a motherboard for $175. Shipping is about $20-25. I "hacked" the SDR file for the board to make it run cooler instead of letting the CPUs get up to the low 80C range. Who at Intel thought that was a good idea? Maybe they don't want your CPUs to last too long...
  38. systemvipers
    283
    Jul 22, 2013
    HI, i tried that link and got
    "The page cannot be found"
    bit i will look for the board in the search.
    thanks for your post, I am guessing that you have to use ECC ram...
  39. Stereodude
    Stereodude 2[H]4U
    3,302
    Oct 20, 2000
    They redid their web store so the links are all different now.
    CPU: Intel Xeon E5-2670 v1 8-Core SR0KX
    Motherboard: Intel S2600CP2J Motherboard
    I'm pretty sure you don't need ECC RAM, but Registered ECC RAM is cheap. You can get 8 x 8gB DDR3 1333MHz DIMMs for $85 from Natex.us
    64GB AM472D3LD4P13C9EC : Kinston 8x8GB 2Rx4 PC3L-10600R
    64GB NT8C72C4NG0NL-CG : Nanya 8x8GB 2Rx4 PC3L-10600R
    8 x 8gB 1600MHz DIMMs are $125
    HMT31GR7EFR4C-PB : Hynix 64GB 8x8GB 2Rx4 PC3-12800R
    Look at the technical product spec http://www.intel.com/content/dam/su...cp/sb/g26942005_s2600cp_p4000cp_tps_rev19.pdf page 48-35 of the PDF file.
  40. systemvipers
    283
    Jul 22, 2013
