HardOCP News
[H] News
- Dec 31, 1969
Sony has developed a thermally conductive carbon fiber sheet that it hopes will one day replace thermal paste.
If it can match or even beat top end thermal compounds, I will be all for it. I have never enjoyed dealing with thermal compounds.
I'm guessing they tested it against the low cost generic product, and not against a product that uses silver, ceramic, or diamond.
It'll be hard to beat skillfully applied thermal compound between two lapped surfaces as the thermal compound layer becomes micro-thin (enthusiasts), but should be very handy for the standard user and business markets where longevity, ease-of-use, and reliability are king.
but.. Sony developed it . . .That would be awesome! I hate thermal paste.
Depends..if it flat out transfers heat more efficiently then it wouldn't be so hard. It wouldn't be difficult at all to have this stuff super thin right out of the box. Couple that with "potential" reuse and it could actually be priced quite high before it was prohibitive.
hell
I'm sticking with grease!
I have the whole process down to a T
What else will I do with my old credit cards?
Besides
Put a glob of hot grease on you arm
and
a heating pad on the other
let me know which transfers the heat faster!
I envoke MythBusters on this one!
Knowing Sony, though, this will be one (or both) of two things:
1) Somehow proprietary
2) Extremely overpriced
Can't make sense of the second part of your rant, but the part about credit cards is totally flawed. That method needed for CPUs (and GPUs) that lack a heatspreader, when you add in a heatspreader things change. Check out this article - http://www.hardwaresecrets.com/article/What-is-the-Best-Way-to-Apply-Thermal-Grease-Part-1/1303/1
This doesnt even include a discussion on the high likelyhood of you creating a "bubble" of air in the thermal paste by you having it what you think is uniform.
Ooh, let me play.
3) The installation instruction CD will contain a rootkit, and will redirect your network traffic to Japanese tentacle porn sites.
This looks like a project for a DIY-er.
Article says it's silicon filled with carbon fibers inside it. The only catch is getting it thin enough-- 0.3 to 2mm thick.
And somehow expose all your account info.Ooh, let me play.
the best heat conductor there is (Diamond).
Exactly, carbon oriented in the right direction is the best heat conductor there is (Diamond). They just found a way to do it without the diamond part...why wouldn't it work?
My only concern is more non PC electronics as it's also electrically conductive, so forget about using it for power transistor mounting.
You say that in a bad way...
Hey as long as the pads don't breakdown like ones in the past I used I for it.
Diamond paste? Really? Is it more expensive than the unicorn blood I have been using?
+1Knowing Sony, though, this will be one (or both) of two things:
When I bought my the AMD Athlon 3200+ back in 2005, the CPU came with HSF that had a thermal pad on it. No paste needed, no messiness, it was great for stock. I wonder why the pad never caught on. But I guess this thermal sheet is a thinner version of that pad.
+1
This would be neat, I hate getting grease all over my pointer finger. But I am definitely waiting for temps before purchasing. Hopefully other companies can come out with competeing products.
This is the only thing that should ever touch that thermal pad.
