The Raspberry Pi 4 is here
Mode13
I would have preferred to mini DP ports.
Would have been nice for me as well since I have mini dp and mini dp to hdmi cables laying around.
This isn't a huge deal to me but it does drive the cost of a pi 4 up to $65 for me due to needing a cable, that's about the gist of how I look at it.
defaultluser
[H]ardForum Junkie
Mode13
I ordered RPi4 4GB version :D
This will be my first Raspberry Pi ever
Where did you order from? I'm about to order a starter kit from Canakit since that seems to be the only thing not on back order until july-august
/dev/null
[H]ardForum Junkie
I believe you have been able to stream from PLEX with older Pi units, and this one is even better.
I really wish they would support POE on these little guys, how easy would that be for those of us with POE switches already!
There are a few options for that -- there is a POE hat, as well as this
CrimsonKnight13
Lord Stabington of [H]ard|Fortress
I use the rockpro64 for Pi-Hole (on Manjaro ARM), which has way more power to it than the Pi 4. I think it can work as a great emulation station, too.
SPECIFICATIONS
  • Rockchip RK3399 SOC with Mali T860 MP4 GPU
  • LPDDR4 RAM (up to 4GB)
  • Gigabit Ethernet
  • Micro SD Slot
  • eMMC Module Slot
  • SPI Flash 128Mbit
  • 4K Digital Video Out
  • 2x USB 2.0 Host
  • 1x USB 3.0 Host
  • 1x USB-C Host (With Video Out)
  • PCIe 4x Open-Ended Slot
  • 40 GPIO Pins
  • Expansion Bus
  • PI-2 Bus
  • Touch Panel Port (TP)
  • Display Serial Interface (DSI) Port
  • eDP Port
  • Stereo MiPi-SCI Port for 12MPx cameras
  • IR R/X Port
  • Real Time Clock Port (RTC)
  • Lithium Battery Port
  • CMOS Sensor Interface Port
  • Optional 802.11 AC + BT 4.0/5.0 Expansion Module
  • Headphone Jack with Mic Input
  • 5.5″ Barrel Power (12V 3A/5A) Port
Darunion
SPECIFICATIONS
  • Gigabit Ethernet
  • Micro SD Slot
  • eMMC Module Slot
  • SPI Flash 128Mbit
  • 2x USB 2.0 Host
  • 1x USB 3.0 Host
  • 40 GPIO Pins
  • Expansion Bus
  • PI-2 Bus
  • eDP Port
  • IR R/X Port
At 2X the price, I would hope it is faster. That is a nice board but is starting to move beyond the intended market. Haven't heard of it but thanks, added to projects folder bookmarks :D
owned66
are all A72 cores created equel - why are there so much discrepancies when it comes to performance vs other A72 chips
afaik this quad core A72 pi is the slowest compared to other A72 chips
defaultluser
[H]ardForum Junkie
Did you take into account their clock speed differences?
The A72s on smart phones probably exceeded 2 GHz.
Verge
[H]ardness Supreme
I believe so, but they have higher clocks and most phones are using like 6 cores now, or 4 big cores and 2 little cores.
tangoseal
[H]ardForum Junkie
I have a pi3 and it's a great Unifi and PiHole and Mumble server.
But a Pi4 might be on my list
IdiotInCharge
[H]ardForum Junkie
Looking at the Pi 4 and the Jetson Nano as mentioned elsewhere, I have a hard time looking away from the Nvidia part- Nvidia puts Maxwell (and thus well supported) graphics on it, runs the clockspeeds much higher, and supports dual 4k60 outputs and has four USB 3.0 ports, while otherwise being hardware compatible with Pi parts. Also Nvidia used Ubuntu 18.04 LTS for their OS base.
Now, if you're not going to use that stuff, I see no problem grabbing a pi 4 for many uses. I just started playing with Raspbian in a VM, and I do like how lightweight it is.
IdiotInCharge
[H]ardForum Junkie
I've struggled to get Unifi (and UNMS) and Pihole all running on a single instance. Right now I run two Ubuntu Server instances on my CentOS NAS for this purpose, but I really do not like having them on anything resembling a 'desktop' system. If I could get that figured, a Pi 4 would be excellent!
andrewaggb
Yeah, though I will say that having a PCI-E 4x port is great for the price.
How have you found it? I tried pricing out all the pieces to build a surveillance NAS with it, the nas case, 5a power supply, fans, adapters, etc, and it's getting close to the price a really cheap pc. It's still quite a bit cheaper than a pc, but not as cheap as I'd like for the compromises I'd be making. Unfortunately most of these SBC's don't have sata ports or a case to house 3.5" drives. This rockpro 64 actually does (sorta the sata ports are an adapter)
mikeo
I would think old ebay parts or old PCs would always be cheaper, main advantage to SOCs is power usage and size.
tangoseal
[H]ardForum Junkie
Easy raspbian and just
Start sudo apt get install'n away like a crazy man. Just watch your 1GiB ram cap.
If you need more help.just PM me and I'll send you some websites that have step by steps
Unifi and PiHole all run at same time and Mumble and a couple other things I have jnstalled.
cyklondx
can we get dual Gig eth instead of usb? mkay thanks
// would really allow me to make small factor pf firewall
IdiotInCharge
[H]ardForum Junkie
There are significantly better options for this purpose. While a Pi 4 might be effective in a pinch, you really want an x86 system with hardware encryption acceleration or a purpose-built ARM or MIPS system. Mostly because you'd want it to do more than just firewall ;).
cyklondx
sure but those cost far more. If you could remove that usb3 ports and put a 2nd single 1gig eth it would be enough for me.
cyklondx
That's 640MB/s, or 5Gbps, on USB 3.0.
Gigabit caps at 125MB/s, with real data (minus protocol overhead) at around ~115MB/s.
The Pi 4 can definitely handle it. ;)
hmm yeah; you are right. i would only have an ugly dongle instead.
