Majin said:I like the coils on the tubing!
But what kind of tube is that?
I am guessing it's not Tygon.
Derrick70 said:the rad and pump![]()
Dillusion said:um, to my knowledge the aquainlet is to be installed without the grey cover on the pump, as it need to leech onto the plastic nozzle of the intake of the pump.....
Derrick70 said:
Derrick70 said:the threads are g 1/8 so they can run a fitting of 3/8 id and dd has some that are 1/2 id.
and it is a mixed loop as far as metels im running a noncorosive fluid and every thing is annodizedo im not woried about it.
newtype said:ah very kool! I am considering some of these peices for my project, but I deslike aluminums ability as a heatsink (voltage and ram coolers). I was considering paying the machinests at my fathers work to mill me something simmilar out of copper or brass or possibly even silver, because I really do not like switching tubeing sizes and ruineing the contiunity of a system.
Also I'm very intristed in the preformance of the ram coolers. The construction looks solid but the actuasl preformace quality to me looks some what shotty to me. if you could maybe post some temps with the ram with and without the blocks I'd really appreciate it.
Thanks for all the info.
Derrick70 said:i would only be able to give you temp with the coolers on because if how big of a pita it would be to pop them off also with every thing thats in the case my air flow suffers some that was the main reason to water cool them to begain with.
0mega said:I hope for your sake thats clear PC Ice![]()
0mega said:one sec ima dig up Dillusions horror story for you 0_0
http://www.hardforum.com/showpost.php?p=1028659422&postcount=38
Derrick70 said:i also seen that the pc ice problem was fixed and it was some older bottles that had that problem when i orderd mine i told Wes over at sharka to look at what he had on the self and give me the 2 that didnt have the floaters in them or the hazy look. my system wount be up and running till next week some time so ill let the bottles sit and see if any thing happens. good looking out tho
