The Lian Li Gallery
Very nice, I was waiting to see someone post pics of that case. A little over top for me but a beautiful enclosure none-the-less.
On a seperate note, I don't know if I've ever seen as many "X"s in a single signature line before. :p
nice.. i would like to see more pics as well.. especially the water cooling setup.. where are the other components? ie.. the radiator?
altpimp..ill try to take pics of the side later...
here is the 360 rad
my temp, im only using an anemic 2xNoctua P12(1300rpm) fan on a 360 slim rad nexxos
this is my next step for my x500..im still not really convinced with this idea of mine..
will cut a bigger hole to accomodate a 2x140fan..and mount a wider rad 420gts
How did you get a factory finished edge on the cutout? Did you paint it or use a black marker maybe?
What color of tint is on that acrylic? Last time I went to my local plastics shop they had like 5 different shades of that smoke color. I took some sample squares home and still don't know what to pick. They all look good. :p
fusionxp...i made it by myself..i use a round file and flat file then paint the edges with flat black
acrylic is tinted..you can check the details in this website www.gammods.com.au
Here a few pics of my case. Not finished yet, but soon it will be.
Not painted but gold anodised.
Original
After build up agian.
With the Feser 360 rad installed.
With my new top cover the T-713B.
D5 Bitspower Pomp and case floor mod.
I hope to finish the case within one week
Original
you beat me to it, i was planning on building a similar setup, same case with top.
question tho: do the 120mm fans line up with the top panel and the feser radiator without modification? cuz i was planing on putting a different radiator up there if i did the build, and i believe a swiftech or black ice radiator screw spacing differes from the feser.
thanks
sicminded said:
question tho: do the 120mm fans line up with the top panel and the feser radiator without modification? cuz i was planing on putting a different radiator up there if i did the build, and i believe a swiftech or black ice radiator screw spacing differes from the feser.t
The old Fesers have 17mm space between the fan holes and the newer ones 15mm. Same as HW Labs and Swiftech. So no modification was made.
Just got the PC-V1010B
[.IMG]http://farm4.static.flickr.com/3200/3047926992_baca26a7e0_o.jpg[/IMG]
[.IMG]http://farm4.static.flickr.com/3176/3046838504_8657d13318_o.jpg[/IMG]
How do you like the case so far? I have the silver one, it is a bit bigger than I expected but it is surprisingly very quiet on the lowest fan setting. I am thinking about replacing the bezel's with the regular bezel instead of the mesh ones.
It's great, I love it. It's very spacious(coming from a first generation P180). I will be sticking with the stock bezels since I installed a 5.25 HDD bay with a 120mm fan just for air intake.
The PC-V1010B looks pretty sweet, V1000 layout in a "normal" right side up layout without the excessive front mesh.
Me likes.
Don't buy these Cooler Master fans...LEDs are stupidly placed. Get them if you do enjoy being totally blinded when looking straight at your case.
I haven't changed much, just made the cables kind of "flow" a little better...
I might get a different Bulgin power switch... might not... haven't decided yet.
I just sleeved a glowing sata cable and I love the effect it creates...
makes me think data is flowing through it :D
Nice! A Cooler Master Hyper 212 on the CPU. A very underrated cooler IMHO. The four-direction orientation is what sold it for a commissioned build I did recently.
Wow this is not bad of a build, but you might want to invest in a more "reliable" psu, but if your comfortable with that one then do your thing.
Thanks, the cpu, mobo and ram are 2 1/2 years old actually. Opteron 170, socket 939, DDR.
Despite what people say about the reliability of antecs psus, I have owned three of them in the past five years with zero problems. Although I plan to go with a corsair or a modular enermax psu for when I decide to move to core i7 or phenom II.
You must of gotten lucky then cause my experience with antec psu hasnt been as good as yours, silverstone or pcp&c are the only companies i buy from.
What happened exactly? Just curious, I have the exact same card in my pc, running a maximus II formula though.
nate
