The Lian Li Gallery
Thanks! :)
I used a Jigsaw. I took my time and "let the blade do the cutting." Afterwards, a quick sanding then finish with a sharpie.
very nice. I put a window in mine too, but made it rectangular. wish I would have curved the corners like you. looks sharp
I really wanna add a window to my v1200 plus 2 but i have a 12cm rad in the back and it barley fits with the stock side panal yet alone the acrylic added. theres like 2-3 mm till it hits the side panal and it has the mesh at the top so it would come out like this if i had to cut it.
And i dont think it looks to good like that.
Can i post "unfinished" computers too ? The reason i'm asking is because :
1) i got my PC-A17 and installed computer into it. Or "sort of installation" because folowing points.
2) i'm waiting for IcyDock MB-454 to return from RMA (should be at friday), that would make current HDD installation (into the cage + 1 disk on top of it on isolation material :D ) obsolete
2) i'm waiting for black SATA cables to arrive from Netherlands (should be here next week)
3) i'm waiting for C-01B (at least 3 weeks, unfortunately) and BZ-502B (replacing the original disk drive bay as i need only the fan installation from it
4) waiting for Scythe Kaze Master black 5,25" (no exact time, seems like black is sold out worldwide :-D, just look at frozencpu for example), unfortunately my Zalman MFC 1 Plus is not really working (it seems so) and Kaze Master is the thing i need as it can stop the fans too :).
atleast hes consistant, look at the mess on the desk. :)
Nice build, but you should get something done with those wires.
It would be good to know what those wires are for. Because i can't imagine for what do you need sooo much wires.
Btw, here is my updated PC-V1000 cabling. I moved hard drives from the HDD cages to the ultimate antivibration solution :)
This is the interior of case :
And here is that antivibration thing :
If anyone is curious what the hell is that, then it's a slovak product called HDD Vibration Killer, and it does what the name promises - no vibrations from disks can't pass trough this to case.
I have to ask you people, owners of the Lian Li v-2000.. Is the R-ATX layout good for the NB and CPU heat conduction? I have read some reviews that says R-ATX will make today's and future motherboard with heatpipes to conduct heat much worse that Standard ATX.. This is also the reason why Lian Li abandoned the R-ATX layout for their V-2010..
Is this true??
I am planning to get a new case soon as my CM-690 is going to be purchased by my girlfriend.. I am currently looking at Lian Li PC-A70 and the Lian Li PC-V2000..:)
What pics ? I was talking about rurd2di's PC :-D
Yeh, so many wires from various things in der..
i tried my hardest but thts about the best i can be bothered doing. I dont really care to much as nobody sees inside my pc anways. its stealthy:D
Where do you guys get the screw for your 120mm case fans that is longer than the usual case fan??
I have a fan grill that I want to install to my fan, but the screw is not long enough to go through the grill and the fan at the same time..
ztigerb... nice mod on that Sunbeam... I love that rig... nice work!
Here's my new rig... I just did a complete overhaul...
I swapped the PCI slot cover plates with an Antec P182 SE and I love how that turned out... plus it lets a bit more heat get away from the 8800. The CoolerMaster Hyper 212 is nice, keeps the quad under control... but I hate the stock fan mounts so I modded it a bit to make the fans easily removable in case I need to clean them or swap them. Then I put rubber washers all over the place to dampen the vibrations. The green is much more green than the pictures are showing... more electric green you might say... I love it :D
Hi, if anyone is interested i did a small review of PC-A17 (unfortunately in Slovak language, but pictures are international :D, you can go to next chapter of review with "Následující kapitola" link ) :
http://www.svethardware.cz/forum/showthread.php?t=18463
PS: I'm waiting for components which arrive today to finish the build and post final pictures here, but i will finish build only at Monday.
TooBooKoo, I really really like the way your case turned out and it has the word clean all over it.
Thanks guys... I appreciate the compliments. I just found some new fans that I might replace the green ones with... I haven't decided yet though. I'll post some pics if I decide to change them.
Here is mine, still a WIP!
Here's a couple of things that I need to do before I consider it done.
1. Buy a 24 pin extension that isn't sleeved and then sleeved them one by one, or should I just buy those molex removers and then do it on the actual connector? It's long enough anyway. Do hardware shops have those molex removers or whatever you call them?
2. Disconnect the PCI-E connector and sleeve them just like what I'm going to do with the 24 pin power connector.
3. Thinking whether I should put back the rounded IDE cable instead of the flat one...
4. Fix rattling noise on the front fan...I really don't know where to look so if you have an Armorsuit and you fixed it, mind sharing it?
5. What do you think of me painting the interior flat black?
I'm def not a fan of the armoursuit, but I must say, that is one very nice and clean setup you got there. Good job!
Does that armorsuit case come with the 3 120's in the front or is that a mod?
Also, it looks similar to the rocketfish case in size. Would a pc-7x side panel fit it?
Yeah my Armorsuit came with three 120mm fans at the front, one 140mm at the top vent and one 120mm at the back.
The only thing that sucks is you can't put a fan controller with a knob at the front and if you load up your flash cards, you can't close the door, but other than that, it's fine.
I hate LEDs. I'm itching to replace them all with plain black less than 1500 rpm fans. Got any suggestions?
Click pics for full sizes.
Lian Li PC-A16, with the HD cage chopped up a bit to allow for reverse mounted drives. Wiring isn't too clean, but it is acceptable for now. Need to track down a decent fan controller because the Yates are just a wee bit too loud for my tastes. I like it :D
I have the 70ish CFM ones from Petras. I haven't gotten the yate on the heatsink yet (had to cut it a bit if I wanted to use the rubber mount dealies. I bought one for the side intake box thingy, but I took it out because I really don't need more noise. I might put it back in later.
http://rageaholic.net/brian/comp/raw has a few pre-assembly pics as well.
I'm glad i bought PC-A17 due all the cablemanagement holes and tools at back of motherboard tray. I will try to post some pictures about final build today, the temporary build was like this (beware, i didn't tried to do any cable management, as it would have no use once my MB454 arrived :) ) :
Lian-Li FTW. :)
Unfortunately the CPU heatsink makes the removable motherboard tray useless though. :(
I've got my Lian Li up and running! Oh, man, she's beautiful. Everything I could want in a case.
More pictures coming as I work to finish up the project. Eventually it will be a bit more custom than it is, but this is just the beginning.
