drpenicilin
- Jun 23, 2008
For those who have the new s5000 series. Have you ever tried to put any micro-ATX motherboard inside? Does it fit? Does it work?
I have just had to replace the motherboard on my S3320, but the new Motherboard has the normal 24 pin atx connector, but the stock power supply has the 'small' 24 pin connector.
Ther seem to be plenty of adapters going the other way when you upgrade the power supply, but I can't find an adapter to got from the small connector on the PSU to the normal ATX on the motherboard..![]()
jeremyshaw, could it be some issues with the motherboard backplate's fitting? I mean, can I replace the original one with the new micro-ATX board that I want to use?
I recently bought a used s3000 series Slimline and am in the process of upgrading it for use as an HTPC for my family. I've spent the last few days skimming through this thread (which is an amazing resource) for ideas and have settled on either an ATI HD4350 or HD4550, plus a 1TB hard drive. I'm hoping to keep the stock 160W power supply and have a couple questions about wattage and cooling.
Many other questions have been answered by reading through this thread so thanks to everyone who has shared info.
Thanks for the help, looks like I would be better off with a new PSU, where can I get an inwin 300w shipped to the UK ?
Well, I decided to upgrade my memory in my s3020n and ran into a problem.
I installed the memory, 2 sticks of Corsair 2GB, to bring the system up to 4gb. I used DDR2-6400 memory. When I booted up my PCI Intel Pro/1000 adapter in the PCI slot was recognized and showed as installed in Windows, but wouldn't actually function. It couldn't pick up a DHCP address and assigning a static address didn't work either.
When I put the 2gb of PC2-5300 back in the network card worked fine.
When I put just 1 stick of PC2-6400 in the network card works fine
When I put 1 stick of 2gb PC2-6400 + 1gb PC2-5300 the network card works fine
Only when I install two 2gb PC2-6400 memory sticks do I have a problem.
The memory I pulled is 5-5-5-15 1.8v, the memory I'm installing is 5-5-5-18
Windows memory perf test went from 5.5 to 7.0 with the 4gb 6400, but I can't use the network once installed.
Any thoughts?
Machine Specs:
s3020n
CPU: AMD A64 X2 5600 2.9G AM2 65N R - Retail
Memory: (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300)
GPU: ASUS EAH4550/DI/512MD3 Radeon HD 4550 512MB 64-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Low Profile Ready Video Card - Retail
HD: 500gb Seagate 7200rpm
Network: Intel PRO/1000 GT Desktop Adapter
jeremyshaw,On an off note, the 8500gt is fast, rather fast (well, relative to whatever intel makes), but it's heavily limited by it's memory bandwidth.
Until I got the 9800gt (sparkle), I had never realized how slow the limited memroy bus was.
Is that the reason why many NerdRage people on forums bash the 8500gt? Or is it just that much slower? (to me, the 9800gt only has faster loading times for CoD4[the only game I have], but I have never seen any 'jerkyness' or 'lag issues'). Or is Call of Duty 4 that much better coded then other games?
check out www.monoprice.com for the cheapest cable deals...You could buy 30 foot of coax cable for cheap.
jeremyshaw, I still have one more question! I'm about to get one of those s5150t but I'm concerned about the length of my Galaxy 9600GT LPLP and all those cables inside the Slimline just in front of the PCI Express slot. It's going to fit anyway?
