Yeah - using the USB connector (love it). Can't see the Amp reading but if it's only 1 that means those 2 fans are eating at least 10 watts, maybe more - Egads! Did your PC50 arrive?
sorry to ask but sometime back someone posted a link to an adapter for a 300w psu and the connector to the motherboard. Can some kind person post that link
My bad I found it as well as the molex to sata
so with a 300 watt PSU for an intel slimline what is the consensus on the best low profile video card out there?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814187061&Tpk=NVidia 9800GT (low profile)
Will be throwing up a spare Slimline with blu ray soon in classifieds if anyone is interested
it looks like the sparkle requires a 6 pin connector. The 300w psu I have only has a four pin. Am I missing something here?
Arch
1) What are the dimensions of your stock PSU?
2) Anyone know if DVI-I is equivalent to DVI-D?
I'll look more into the sparkle 270. it will guarantee to fit and 270 watts should be enough, is this correct?
edit: is this the correct one
http://www.censuspc.com/product.php?productid=5902&cat=0&page=1
The spakle 9800gt comes with a adapter for the six pin PCI-E.
you'll need two free molex plugs for the six pin adapter.
Are you sure? I looked at product pictures and was unable to spot a 2x4-pin to 6-pin pcie adapter.
I already ordered one which should come in tomorrow, so we'll see how that goes.
The BE-2350 may work out of the box --- or it may need a BIOS update --- either way it will work. The BIOS update is on HP's site.
Can you provide the link for the ebay seller's $15 shipped atx micro-fit adapter. That's a good price.
Hi Everyone,
I own an s3200t - which I've modded with a 8400GS to off load 1080p decoding. Here's my dilema: This machine was purchased to replace an aging HP z555 running WinXP MCE 2005. I want to move to Vista MCE (and eventually Windows 7) - but I'm having a hard time getting my head around how to fully spec this system. I'd like to be able to put a TV Tuner in the PCI slot (so I can get S-Video from my Cox STB). Trouble is - nearly every low profile tuner card I find is PCI-E.
I'd love to get the Hauppauge 2250 (http://www.buy.com/prod/hauppauge-w...der-media-center-kit/q/loc/101/208809707.html) - but it's a PCI-E form factor, which means I'd need to ditch my 8400GS. Otherwise, I'd go with a USB tuner, but then I'd loose my S-Video in (for my STB digital cable).
Any suggestions? I have a HD HomeRun, so I can get QAM/ATSC via my LAN connection. My goal is to be able to use my STB for all my "analog" tuning needs.
Thanks in Advance
SF
Arch
I've reread the posts about the Seasonic 400W PSU and the top-rated review given to it by jonnyGURU. Has anyone attempted to install this in a Slimline? It's a longish sort and may not fit? - also width-wise. Height appears OK (40mm). I sent an email to Seasonic, asking them if they are aware of the fan noise problem and if it can be fixed (by them or someone else). I'd say there is a good-sized market out there for a stable PSU upgrade like the Seasonic that fits the bill (or the case!). There must be heaps of under-powered Slimlines out there and aficionados (fans) anxious to play the latest games on them!
If the PSU-shoe fits, some of us might be willing to wear it - noisy fans and all. After all, don't those games produce some DBs!?
Have you checked out the Hauppauge WinTV-HVR-1950 USB TV tuner? It supports S-Video since it comes w/ a little box. I have this TV tuner and get great HD from it. However, I'm not utilizing its S-Video, so I can't talk about it from first-hand exp. Note that it's a little pricey ($130 MSRP), but Newegg runs sales and MIRs on it occasionally.
Just picked up a new hp slimline s3720f. I wanted to upgrade the video and have a Gigabyte GV-NX84S512H GeForce 8400GS ordered. Ive seen conflicting reports in this thread regarding a PSU upgrade being required. Please elaborate
Halsey, --- A intel based slimline should NOT come with a 160 watt PSU
