I have a s7600n (the older, silver case) - do we discuss those here?
Note that not all low-profile coards are listed as such on NewEgg.The following cards don't even require auxiliary power - just what the PCIe x16 bus provides:
ATI 3450
ATI 3650
ATI 4350
ATI 4550
Here's the current list of all low profile PCI-e ATI-based video cards that Newegg carries.
What motherboard(s) are these using?now we have a 3700z, 3710t and 3750t with 230W PSUs... http://www.shopping.hp.com/webapp/s...anding=desktops&a1=Category&v1=Slim and sleek
Archaea,Take the TV tuner card out...it'll still draw power if it's plugged and certaintly generate heat. They are super easy to remove. The first post has a link to the HP user PDF for maintenance on the slimline that will show you anything you need to know about upgrading/servicing the slimlines.
Hey, John16 - that looks really cool!Pic of the day...
I just received the LED fans and thought I would mount them right away. I gotta say that I really like this mod.
It is associated with your wireless...IIRC.
thanks, that's what we suspected. Will be part of the antenna?
I installed the 450w supplemental psu and 9800GT and it runs FLAWLESSLY!
...shifting my interest to the 300W PC50 you just ordered. In reading the dimensions of that PSU, they are all slightly larger than the stock PSU in my S3323w. I think the 160W dimensions are 150x80.5x40.5. Are those the dimensions of your current PSU? Will you need any extra bits, pieces and connectors like those needed for the 270W install?
...processor at 45W? Which one do you recommend (with heatsink and fan, I assume)? Will any AM2 processor fit onto the M2N61-AR mobo?
What practical benefits would I get by upgrading to the AMD 5600+ and staying at 65W (it doesn't seem to make sense to downgrade my current processor (AMD 4800+).
Does anyone know if the default fans included in the Antec mini cases (350W 80PLUS) would be enough to power the Sparkle 9800GT (along with an E8400, 1 hard drive)? I'm thinking about that video card for my next build but in a slightly large case like the Antec Minuet 350...
I have a slower slimline, which My question is this: Is the vid. card fried, or the pci-e slot on the mobo? I haven't been able to test it in another machine.
SlimkiwiI think you'll likely be able to run the fastest 5050e, 2.6Ghz X2 45 watt AM2 processor.
Hey Arch - how many watts are these little fans eating?
