Can I use any regular Memory ? are addditional tweaks required ? or is this just plug in an go ?
Hope Kakawak or anyone else can answer my question !
thanx,
Don![]()
hi there
if you use the memory ive quoted in my description you will be fine. there is no tweaks needed for my setup to work and yes it is a case of plug in and go you should be fine however, many people in this forum dont recommend my setup so its up to you if you follow suit!
my pc is still going strong and im playing crysis, red alert 3 etc... although i still do have venting problems which im trying to fix! as you will know this baby generates enough heat to melt the icecaps so when that is fixed im sure any problems ive had with lock ups will dissapear. i must say i wish they would release another bios update for this slimline!
regards me
