Archaea
- Oct 19, 2004
some models of 8400 do - some do not...That specific model you'll have to read up on. I know the XFX 8400GS (a model I own) does HDCP.
Does the 8400HD do HDCP? I guess it doesn't matter if you're not going to do Blu-Ray with it.
TIWizard- Keep us posted on your Radeon 3650. I hope it works. I was looking at a Radeon 3450 as a possible video card update, but I'd prefer the Radeon 3650 if the Slimlines can handle it.
Seems to be working great...
Vista scores:
3450: Graphics was 4.0
3650: Graphics are 5.6
That's great news! I will keep the airflow problem in mind. Recently I've been thinking that I might try this fan mod using those laptop cooling fans that 360spider found. Seems like a good idea for airflow improvement. I was wondering though, where did you get your card? I'm having a hard time finding a low profile 3650. Thanks.
I have a S3200t which started out with the base 2gig ram. After speaking to HP, the said that the S3200t can handle up to 4gb. (Yes I know Vista will only show 3.2 or so).
I purchased (2) 2 gig sticks of DDR2 PC2-5300 667.
When I went to install them, my cpu would not POST.
I tried reseating the ram, but everytime I get a beep code. One short, one long, repeating.
I tried each stick by itself, together, even with mixed with my 1gig sticks. same thing, until I go back to the original 1gig in both slot, or just 1 gig in one slot.
I know it is possible that both sticks are bad, but this seems likely not, but I maybe wrong.
Also, this is not my first rodeo with upgrading ram, but certainly has been the most trying.
Has anyone ran across this before?
I have scoured everywhere with little results, but keep ending up back here... I have read through about 45 pages or so of this thread and have searched, but didn't find this particular issue.
Any thoughts or help would be greatly appreciated.
The slimline only puts out 1.8Volts to the dimm slots. My first guess is that your RAM requires 2.0-2.3 volts.
Hi, Does anybody know the VISTA score for the ATI HD4550. I can get that card in LP format just about anywhere in the UK. I was wondering if its THAT MUCH better than my ATI HD3450 which scores Gaming 4.1, VISTA 3.7.
.....And the bigger problem would be that the motherboard would be on top making all the heat soak into the motherboard as it rises if you wanted to be able to use your CD-ROM
Also the bottome of the case is slighly bloomed out right - so it wouldn't lay perfectly flat either I don't think.
The vast majority of side holes would be on the underside me thinks
For those who beefed up your Slimline's PSU, you can also check out this video card:
SPARKLE SX96GT512D3L-NM GeForce 9600 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Ready Video Card - Retail
Newegg is currently selling it for $100. Credit to stevedave for informing me in another thread.
The score for my Sapphire HD 4550 512MB < 25w of power consumption on my Slimline s3041la 160W PSU, running without any problem so far.
Graphics 5.1
Gaming 5.2
Still waiting for the Sparkle 9800 GT Low Profile....
Sparkle to Release Low Profile GeForce 9600 & 9800 Cards
There's quite a few things I like about these cards:
1. GDDR3
2. 512MB of it!
3. Looks to be a lot more quiet than the KFA2 9600GT.
4. Roughly double the stream processors on the 9800GT (112) from the KFA2 9600GT (64).
5. HDMI(!!!!!) and DVI
6. Comes out in January
Cons:
1. Needs an extra PCI-e power connector. (No prob for me.)
2. Gigantic heat sync. (Don't plan on a PCI card with this.)
Providing power consumption is within range of my current 9600GT, you can be sure I'll be upgrading to this ASAP.
Here's some more high-res pictures of the cards. Click on the pictures at the bottom.
