All good! I thought it was something like that, and dropped a few characters at the end, but still nothing came up. I guess I didn't drop enough.
thanks!
it's fine!Well crap! I've looked all over and am not finding the box of parts or anything. I moved about 5 months ago and might have tossed all of it or something.
If I do run across it I'll certainly shoot ya a PM but I'm not very confident in finding it bro. Very sorry.
Search resulted in no info on these. What are they?
https://www.amazon.com/replacement-L550-ST2721-L550-ST2722-L550-ST2743-L550-ST2744/dp/B00DA9MLTGDo anyone have a Toshiba laptop power supply (L550 series) that is no longer being used or needed?
Looking for low profile slot cover for Dell 3020
Or dead vid card from same. I have a gt 640 vid card and can remove the vga output but need a slot cover for the DVI and HDMI outputs.
I bet I do have one, have had some Toshibas go through. I just don't know how to figure out which one it is. I usually just keep them until a brick goes bad on another laptop and then I just swap the P.S.
hmm .. never had any issues with cheap "power bricks" .. off of Amazon or Ebay. So I was recommending off of personal experience. I've purchased dozens of them over the years.Don't recommend terrible counterfeit Amazon power bricks. Those things are fire hazards and laptop killers. I've had dozens of customers with destroyed or damaged laptops because of those things. I've also seen plenty of them forcibly detonate and blow the casing completely apart because they're so shittily built they self destruct when loaded down to their "rated" spec. I would in fact not recommend buying any laptop power brick from Amazon, because if they're not dangerous counterfeits, they're bait and switch dangerous counterfeits. I've bought and directed customers to buy listings that had pictures of real genuine OEM power bricks, only to be sent a counterfeit bait and switch in its place.
There are actually very few third party power bricks that are of decent quality and are trustworthy enough to use. The only three I've come across the past decade are Intocircuit (they seem to be defunct), Blackweb and Targus. They're all a bit pricey, but they're well worth the cost.
Targus:
https://us.targus.com/products/90w-ac-universal-laptop-charger-apa31us
Blackweb:
https://www.ebay.com/itm/324263013360
The best choice is to buy an OEM adapter if available, but when they're not, it's better to use nothing than garbage chineseium generic power bricks.
I found this genuine one, which may work.
https://www.ebay.com/itm/184411403694
does anyone have an extra empty 7" audio tape reel?
I may have a nVidia Shield controller up for grabs... I need to make sure it works and has no issues.
Still looking for my old Intel G series processor.... If I find it, I'll send it.
interestingly enough, I bought 2 full (7") tapes for 6$ and cant bring myself to empty a spool or spend that much on a single empty spool.One of these things? https://www.ebay.com/itm/123226134472
>> insert 3d printer and supplies here << I wishMaybe 3D printing is an option, it'd probably a few dozen cents of plastic.
basic socket 775, FM2 or 1150 microatx motherboard. Can be OEM. Just making a budget emulation build
I've got a new HP Elitedesk 800 G1 (This one) microATX board and the PSU adapter cable. It's actually about an inch or two longer than mATX spec, but it does have 4 memory slots. I don't know if it works, I don't have a CPU to try it with. It also has non-standard HSF mounts (73mm x 100mm IIRC), so you would need either the OEM heatsink or to bodge something together.
Anyone have any DDR3L SODIMM?
C13 PC power cords. I need as many as i can get in one flat rate box. I bought some from ebay and the gauge wire inside is so thin, the plugs heat up just powering an LCD monitor.
I'd like the A10-5800 and the Athlon 64 X2 6400+.
What size USPS flat rate box? I can get used good condition PC power cords for a dollar or two a piece if you want to pay that plus freight. They won't be the Chinese fake copper coated aluminum wire that's severely undersized and padded with plastic.
Ok lmk.I might bro. I'll look tonight when I get home. I think I have a miss matched pair.
Super tempted. let me see if i can spot the heatsink for this before i take the plunge.
what size are you looking ?Anyone have any DDR3L SODIMM?
I'll take whatever I can get, but an ideal purchase would be 2x4GB 12800what size are you looking ?
Needs DDR3L unfortunately, but thanks.Not DDR3L but i do have this stick
https://www.amazon.co.uk/Kingston-A...Pin-PC3-10600S-9-10-F0-Notebook/dp/B00HJKPEW8
EDIT: System currently has a single 2gb 12800 so I can match that, add to it with whatever, or upgrade to 2x4GB.
I'll take the 4gb, worst case I keep looking for a match to it. The 2GB aren't compatible as they are 1.5v modules per google. Paypal ok?I should have the following:
2 2GB Elpida PC3-10600s EBJ21UE8BDS0-DJ-F DDR3 SO-DIMM
1 4GB Micron PC3L-12800S MT16KTF51264HZ-1G6M1 DDR3 SO-DIMM
Unfortunately I don't have 2x4GB, but if no one else comes through you're welcome to any of those.
No rush, let me know when you get the chanceYep, but let me double check to make sure I still have it. I just looked at my spare parts spreadsheet earlier. I *think* it's up to date, but I'll want to double check before accepting anything. I'll PM you later and let you know for sure. Thanks!
Would this works ?No rush, let me know when you get the chance
