Top Nurse said:I got a new use sent to me by Wes at Sharka. He says the big round center hole is for making sure you get a nice straight cut with a razor blade. Gotta try that.
Derrick70 said:did you make a trip to sharka today?
Dillusion said:She lives there.
Mysterae said:Damn, I thought you said multipass...
Top Nurse said:Yes and so did your 160 grill.
BioPort said:teh roflcopter could use it as a cock ring.
LadyMakoFox said:I dont think any guy would admit to using one for that esp since the holes are tiny...
mohammedtaha said:Can the largest middle hole screw/unscrew a thumbscrew ?
BellaCroix said:I think the whole thing is Alien-tech. In the event you forget the words "Klaatu Barada Nikto" but need to keep Gort from destroying the world you pull the fail-safe key out of his back and he switches to kitty-cat mode.
Little known fact: Gort was cooled using German watercooling gear and used Windows 51 (It's much more stable, with a more intuitive GUI than Windows 49).
penguin said:Or you could just use scissors...
mohammedtaha said:How about a carrot (whatever) peeler.
No one suggested that yet ... you never know, German's love food.
knaSen said:The smaller holes can also be used to connect the tools together to form a necklace or maybe even a tool-mail, kinda like ring-mail armor but with AC-tools! That gotta look schweet!
or just make it a necklace-jewlery by attaching a chain to each hole and maybe put in some kind of gem or LED in the big hole
L1ght said:Guys... Its so obvious that it is a head decorating peice. Just push some hair threw it and use rubber bands, boom, ac mini hat like thing.
mohammedtaha said:or you can mod it and make it a cigar tip cutter ... duuh ... Aqua Computers wants you to mod it dammit
mohammedtaha said:why didn't they settle the problems in windows 50 ?
And that is why I don't use push-fitsTop Nurse said:I wouldn't recommend that as you will not get a straight cut and your push-fit would probably leak.
