Sure it's not the mobo? Does the mobo do better with another chip?
he does have a ds3.
C2D overclocking is a bit odd IMO.
I heard all these great results and yet I cannot get my e6400 over 3GHZ and I can not get my e6600 over 3GHZ without tons of power.
Now, I think most also do not do as much stabilty testing as I do, I like at least 10hrs when most stop at 4hrs and call it good....
I'm more anal than you and do 12-24 hours stability testing and I was able to go up to 3.4 GHz 24h stableIt also has to do with the motherboard ability to help with stable overclocks, a good pick on memory and a excellent power supply (this is often the most overlooked piece of the computer).
Uh, anything better than stock is good, no ? It's only guaranteed to run at stock.
Yup, I have a good Mobo (P5B-E), Good Memory (DDR2800 and it runs at that fine), and one of the best PSUs, the Corsair 620HX.
Agreed. But people around here seem to think you should get to over 3.0GHZ easily. Because some have doesn't mean all will. I think people saying you will get there easy is what makes people feel down when they dont get there![]()
Perhaps you're doing something wrong.
I have the original P5B vanilla board. Have E6300 @ 425FSB 2975mhz on some cheap DDR2 667 chips. You should mess with the ram timings.
I registered just to reply to this. My new e6600 needs 1.4V to run stable at 3GHz. It needs 1.525V to run stable at 3.2GHz (355 FSB). I spent all of today messing around with settings on my P5B Deluxe but can't do any better, and I thought I got the crappiest e6600 ever.I also have tried to OC my e6600 and it is fine at 2.88GHZ but I have to bump up the vCore to 1.48 to get it to run stable at over 3GHZ which I do not really want to do for a 24/7 rig (and my mainboard does not restart properly with a high vCore like that).
The chances of having a bunk 6600 and 6400 that cant go over 3gs is pretty slim IMHO... some people get better overclock than others cos they have more experience overclocking or they give more effort and not just quit.....
Maybe I was lucky with mine but to be honest thats what I was expecting when I bought my rig.... I was expecting 4gs 3dmark stable and it did 4094mhz so a lil better than expected.....
I recently bump into a friend that I havent seen in a while and topic got to overclocking... he gave up being stuck at 3200mhz with his e6300 and said he got a "bunk" cpu.... 5 hours of troubleshooting and he's rock stable at 3600mhz......
People need to understand that overclocking is not just buy, build and set to 3600mhz.....dont wanna sound egotistical but most people that are stuck at below 3000mhz are doing something wrong.... only few got unlucky....
No, it's the 965P.I hope you didnt buy the 965G DS3. From what I've heard (few, but still more than 1 person), the 965G boards doesnt overclock nearly as well as the 965P's.
Yes, that is usually my speech.Uh, anything better than stock is good, no ? It's only guaranteed to run at stock.
I do not have 5 hours to spend on over clocking. So apparently I must be doing something wrong if more voltage and super-relaxed timings barely yield a ``simple'' result.I recently bump into a friend that I havent seen in a while and topic got to overclocking... he gave up being stuck at 3200mhz with his e6300 and said he got a "bunk" cpu.... 5 hours of troubleshooting and he's rock stable at 3600mhz......
No, it's the 965P.
What would be helpful to all is if you described how you troubleshooted your system. What was the problem that held him back at 3.2GHz? How did you figure it out? How did you solve it?
I am usually in disbelief when I read stuff like this. I think some of you guys need a little perspective here. A 900MHz+ overclock is not that bad.
I had a 2.4C that would only do 2.6GHz. Now that was a crappy overclocker.
Power supply and motherboard?
