The "Best" Socket 478 Mobo
Hate_Bot
I was just wondering what you guys considered as the "Best" Socket 478 Mobo? As in the most features, stability an all around quality?
Thanks
One of my personal favorites was the Abit IT7-Max2 Ver.2. That thing was freaking awesome. Only problem was the 845PE chipset was only good through 533FSB and only had AGP 4X. It had SATA ports and came with the "Serielle" adapter to connect an IDE drive to a SATA port. That was pretty neat when it came out (I had never seen a SATA drive). Plus it had 10 USB ports (6 on back). I put that in a Lian-Li PC-60 and was rockin' with a GeForce4 Ti4200 :) and a GB of PC2700 RAM
I had the same questions when I upgraded many moons ago. See sig for system.
People advocated the Abit or Asus boards as best mobo's. I went with the Abit, as it was cheaper and easily available where I live. I'm very happy with this sucker.
most cards dont even use the full 4x bandwith, so 8x wont do that much for ya,
Still, there are some cards that wot work on my sytstem, because I have 4x, when I tried upgrading a while ago, one card didnt work (and its the one I wanted) so I got stuck with this card
Abit Max3 and the Asus P4C800-E Deluxe
I've used the Asus for a while and it's been a great OCer for me and is very stable.
The only flaw that I see with the Asus board is that it has trouble holding CPU voltage if you are running above default voltage. This is a known problem, but wont be a problem if you don't do much with voltage settings. (FYI, there is a hard-mod to fix this)
The other flaw with the Asus board is that it only supports memory voltage up to 2.85v. That's pretty low if you're using BH-5 or any ram that needs lots of volts. I'm using G.Skill TCCD memory and it doesn't need more than 2.8 volts anyway. (FYI, hard mod is available for this too)
The Abit board has a few problems too. It doesn't have trouble with cpu volts (like the asus), but it does have trouble with ram voltage stability. (Hard-mod available).
Basically, it all comes down to your needs. The asus board is my recommendation to you. Even with the slight voltage problem, I've had my 3.4c up to 3.85 without too much trouble (which is AWESOME for a northwood). On a cold day, I even had it up to 4.11ghz. Not only that, but it's also available new (the abit is discontinued).
Hate_Bot said:
Hmm, agp4x is a nogo, I wanna upgrade my curent Mobo, its only 4x support, I want 8x support, so I can use teh faster cards
edit: http://www.dfi.com.tw/Product/xx_pr....jsp?PRODUCT_ID=2720&CATEGORY_TYPE=LP&SITE=NA
Ive heard good about DFI boards, this is one of the more expensive 478 mobos Ive found ($189 CDN). I was wondering how stable it was, and just how good a mobo it is.
Thanks
Haha...I thought you were being nostalgic or something :). I think I had just got done reading a post about old hardware and thought the thread was similar ;) . In that case, the P4P800-E Deluxe is a good board. I used it in a computer I've had for a while now. Also, I just heard that they have some s478 PCI-E motherboards so maybe you'd want to look into one of those.
I use the Abit IS7 v2 and it rocks, I have a 3.4 GHz and it works flawless. I also have a 9800 pro, all of it water cooled. Its the best 478 board out there. I would wait, since the p4 and this chipset are at the end of the life cycle. But if you do that you need PCI-Express Mobo/PCI-Express Video Card, and the new P4
Depends on how long you want to wait bro and how much $ you got to waste :D
Why hasn't anyone said DFI yet?
Love mine. Of course its not OCed or any crap like that, and its been on 24/7 has long as my shuttle board has that cost 1/4 the price.
I was wondering, is there such thing as a socket 478 to 775 adapter? Or a board that con do both 478 and 775?
Thanks
Why, what exactly id wrong with it?
It's just Ive been having difficulty finding a PCI-E socket 478 mobo in canada.
...bah
agbit ic7-max for sure! It's awsome! more than you need
super stable, lots of overclocking options, dual channel mem., etc...
Great board
Don't get the Max3 if you intend on massive overclocking, AGP/PCI bus flakes out when FSB is >300Mhz.
