the Abit IN9 32X-MAX thread
When I sent mine back for RMA I was going out of my mind looking for the anti-static bag to put it back in. An hour later I remebered it didn't come in one. Like you this was evidenced in the holes in the cardboard where this poor bugger was rooting around.
it needs the LRF option.. (little rubber feet) ;)
edit: hey office_m, nice work on your OC! so you're linked and sync'd.. I guess that's the best way to run? I still feel like a n00b in that bios.. lol. I was getting the most stability with unlinked, running the fsb at 1400 (this is with default vcore on the cpu) and the memory at 1000.. did you really need to add voltage to your NB and SB to stablize your OC? I'm going to dig into things tomorrow night... provided this new board, (a) gets in tomorrow, and (b) works well.
Hey.. EVERYTIME I reboot, my POST code reads A0.. This is on completely default settings. NO OVERCLOCKING what-so-ever. My LCD monitor goes into "suspend" mode and my computer gets stuck like its trying to reboot. But it never does. I can't find out any info on the POST code A0. I HAVE to clear CMOS EVERYTIME I reboot. What a pain. Any suggestions or known issues? Any fixes? Anyone else having this problem?
I started getting this also... but I waited for about 20 secs, then the board posted.. it did hang on A0 for a while tho.. but would eventually get through a post.. it was when I set the fsb to 1200.. oddly enough... only then also..
k00lance - I tried with everythign stripped away from the pwm area except for the sinks and a fan.. then again with the stock sink.. it was not as loud with the stock sink, because there's more metal covering things I think.. it really sounded more like air escaping from a tire... a buzz/hiss sound.
Well, I turned up the Voltage early on in my overclocking trials.. It was simply suggested on another site to bump it up just slightly to help "stabilize" everything out.. If that is true, cool deal.. If not, I am unnecessarily running a tad bit more voltage (when it really isn't needed). There is only one way to find out I guess.. I will put them back to stock and re-test my setup and see if I still pass Prime, Memtest, etc..
Also, (this is for anyone who might know the answer).. With my setup, what would be the best route to go..
417fsb x9 = 3.753ghz (I was only stable at this speed when I jumped my voltage up from 1.4805 to 1.5405 volts!
469fsb x8 = 3.752ghz (haven't tried yet)
536fsb x7 = 3.752ghz (not even sure if my system is capable of that FSB! ..See my signature for system specs)
Are there any advantages / disadvantages between those 3 settings?
Oh, I forgot to mention.. I added (2) additional aerocool 89cfm 120mm fans today .. I am doing my best to keep EVERYTHING nice and cool.. It was suggested that my temps are pretty high.. Although I am aware of my temps being definately on the very warm side, they were well within the tolerances and definately not SUPER HOT.. Well, it ate on me.. and ate on me.. and ate on me.. LOL. Soooo.. I went out and bought the fans and installed them a little while ago.. I have NO more room to mount anything.. LMAO!
wow... you have lots of air now. lol. I think trying for an 8x multi with higher fsb number, which runs your memory harder (linked + sync'd) would be the better way to go, if you can get it stable..
@ office.. sorry man but you certainly went overboard with fans...
you shouldnt have listen to those people saying your temperatures were high.. abit boards usually read temperatures a little above the actual temperature
also from taking phyiscs (which I hate lol) there should be alot of turbulense and the airflow should be mess up because of all the fans there..
yeah - I was going to say, if you're trying for 500+ fsb and max voltages on everything, then maybe you'd need that.. but it's overkill for most.. it will likely add more dust issues then help stability.. maybe. It's your call though.. if you like it, then it's all good. :) personally I like seeing the guts of the mobo and such.. like popping the hood on a hotrod. :D
in other news..
ups tracking said:
02/06/2007 07:46:00 OUT FOR DELIVERY SAN RAFAEL, CA, US
come to poppah!!! lol..
same here.. I like to look at the inside of the case.. after all it was my creation lol
lets hope you get it without issues this time..
yes,, lettuce hope. I guess I need to try and OC linked + sync'd... I want to get my 3.5ghz stable back minimally.. then push my memory beyond 1ghz.. it should do it.. I have seen peeps with 1100 and such.. but I guess I will have to unlink it for that.. I should prolly spend today reading up on 680i overclocking.. I still feel like a n00b. :p
edit: I might need to retract that statement.. check this link for lots of 680i OCing info.. apparently the extreme fan idea might be good. :D
Oh, you can turn them off in the bios and the UI tool in windows.. you can set them to be on solid, or flash fast, slow, and alternate in different paternts.. there are like 6 profiles for them.
I actually think the turbulence is not an issue. As a matter of fact fluid flow in the vapor phase is almost always turbulent. There has to be some failry exacting conditions for the reynolds number to get low enough for laminar flow. And besides that, your not talking about aerodynamics, he's not looking for air to move through with the least amount of friction, which is when turbulence would be a factor. Actually highly turbulent air mixes well and you have a homogenous temperature of the air inside.
I think what is important is that you have an equal amount of exhaust fans as intake fans. After all heat dissapation is all about particle contact and temperature differential. Thats why liquid is so efficient, liquid has a much higher particle density thus can carry more heat away. If O-Mart get's more air flux through his case, then he remove more heat from his componenets faster. You just have to be sure that you have good air circulation in the room, or you start to heat your ambient air and and the temperature differential of your ambient air and hot component decreases.
I'll say it gain YAY Transport Phenomenon!!
Well.. I was going to say that, verbatim. LMAO! Not really.. I am not that bright.. haha. Well, I keep my side panel off of my case, just so I can look at the guts.. I bought this case 2 years ago, and have probably had the side panel on a total of 3 times (each time for about a day).. Ever few weeks or so, I blow my computer out with alot of air and then wipe everything down.. I do a pretty good job keeping it clean. Having THAT many fans in there, moving THAT much air, I knew would be a high maintenance install. I am OK with that.. If I had a high end H20 setup, I would feel pretty darn confident about hitting 4ghz. But, I am on AIR. Either way, I set out to accomplish some goals on this build and I achieved every one of those goals..
I am still learning, and love to hear everyone's input whether it be positive OR negative. I will give the 8x multiplier a go and see where it takes me.. Should I leave my voltage on my CPU alone for now or bump it back down to .. lets say.. 1.375v and work my way back up?
Oh hi again.. read the link I posted above (post #129).. the lower multis will lower your memory BW.. but you can try and see how your machine performs with them.. very different from i975x OCing. I thought the higher FSB rating would make things faster.. strange! There's some good info there.. interesting info on cpu HT voltage.
edit: dude - could this day go by any slower?? GAH!!!!!! lol.. mobo on porch.. must go home now.. ;) I have to wait for the ferry to take me home. 40 mins and counting.
OMG DUDE! You have NO idea how that article really hit home with me. I am not such a noob to think I am a really stupid person, however, I had ALOT of issues that were just not adding up! Even if half of the stuff in the article is true, it really makes sense to me, 100%! I obviously read the whole article once.. and then once again. It seemed to really really answer just about every single thing that I have encountered thus far!
1. When I bought this Abit 680i board, it was soooo not like my previous DFI nF4 board (other than it had the capabilities of running SLi). I knew I would have to do alot of listening and asking around to get anywhere with my setup.
2. My Operating System. Sign #1. I installed it.. I tried to overclock on it a little by doing the whole HIGH FSB lower multi on it.. Within 2 days, my OS was corrupted. Unrecoverable. Now I can't even boot the hard drive up or anything. When I tried to repair or even reinstall the OS, I would have NO luck. Period. (Side note, I got my RMA number to eWiz today on that hard drive (Samsung 500gb SATA II). About 5 minutes ago, I bought a Seagate Barracuda SATA II 16mb cache 500gb HDD. I got 2 day shipping and it should be here before the weekend! Woohoo!
3. My temperature(s). Sign #2. Alot of my friends who have Conroes (Non 680i motherboards) were telling me that I must have a "defective" board because my temps were just really on the high side. Well, if I saw anything that really stood out in his article, it was how HOT the 680i's run. And more to the point, how important it is to ACTIVELY cool everything if the board is going to be overclocked. Wow! That really described my situation perfectly to the T.
4. Lower Multi's / Higher FSB. Sign #3. It has been brought to my attention that although the previous rule of thumb with the 965/975 boards concerning multi's and fsb's yield awesome results, the same cannot necessarily be said for 680i motherboards. A few other 680i board owners have contacted me wanting input on this very issue, and up to this point, I was unable to even approach them with any type of solution other than do what others intellegently suggest. I know my Dominator Ram is pretty good but is it FLEXING exactly what it's capable of max'ing out at? Nope. It is not. I know my Ram can "perform" at a higher FSB.. That doesn't always mean higher performance. And in my case, I think it's doing rather well (OVERALL system performance). Keeping the higher multiplier ( x9 for my E6600) seems to be a better overall choice, for my particular setup. I made good on my attempt to run the x8 multiplier and was able to get it to 3.75ghz with no problem. I was pleased to see that. However, just to test the waters, so to speak, I ran 3dmark06 to see if there was any system impact on my already achieved score of 15,431 a few days ago. Indeed there was a score difference. Almost 400 points.. I scored a 15,033. Wow. To me, that seems like alot.
Other things such as timings, dividers, linked vs unlinked, etc were covered like I asked him the questions, directly to his face. LOL. For me, it was a VERY informative article that 680i owners (evga, abit, asus, bfg, etc..) should sit down and read up on, IMO. Thank you REVENANT for linking that article. I am glad you pointed it out to me. I feel a little more at ease with my current setup.. Now.. ABOUT THAT CPU HT VOLTAGE.. Hmmmm.. That's damn interesting!
BTW, are you home yet REVENANT. Did you get your motherboard? Inquiring minds wanna know.. You're back in the game! Post yer pics and any info that you may think would be helpful..
I bet Rev is up to his elbows in PCB and loving it. Maybe he will give us an update if he comes up for air soon:D
Hey $cooter.. I've been digging around in the bios and I don't actually see the option for CPU HT like its suggested on the Asus 680i motherboard.. Under voltage control, I found HYPERTRANSPORT (voltage range is 1.20 to 1.40 volts I believe) ..I wonder if CPU HT and HYPERTRANSPORT are the same monster?
Oh, BTW, I reached 3.8ghz.. I was happy to see that. It runs wayyyyyy to hot for me to even consider that for 24/7 use!
E6600&
Ha... yeah, I am up and running again.. whew.. I pulled the stock sink and added my own AS5 on it and am running with that.. my temps are pretty ok actually.. anyways, time to test some OCing.. what bios are you guys running? beta 2 or the 1.0 "official" (whatever shipped with the board) ?
Im running the shipped factory bios.. About 10 minutes ago, I hit 3.8ghz.. I CPU-Z validated it, so i am pleased with the BIOS as is.. I tried inserting the picture, but it comes up as a link..
sweet... ok, I am going to try this bios then... I hear beta 4 will be out soon and it's supposed to be pretty good.. does yours say
SLI-ready memory - disabled
with beta 2 that was enabled for me by default.. I don't think it matters much.
anyways.. I am up and orthos validating my max stable OC on default vcore for this board.. with my p5w dh is was about 3.2ghz... I am at 3150 now.. linked and sync'd. going to let the board burn in here overnight I think.. just to get it's feet wet. :) I can still hear a faint noise coming from the PWM! gah.. but it's way way quiter than before.. and it seems to be going away now.. the longer the board runs..
right now:
fsb = 1400
mem = 700 (linked + sync)
vcore = 1.325v\
ddr=2.20v
cpu vtt = 1.50v
NB= 1.40v
SB= 1.60v
HT=1.30v
cpu load @ 36c
system load @ 25c
PWM chips are all @ or under 60c!
avg current 38A! wow
Yeah.. I dont have my SLi memory enabled. I left it disabled. Don't know what overall impact it has, but if I'm hitting 3.8ghz, it can't be affecting me too much. I was linked and sync'd but have since only LINKED.. under the sync'd option, if I left it sync'd, it said my memory would have been at 800.. Well I have 1066 modules so I manually set them to 1066 (not 1066 by CPU). If you have 800 stuff, Im sure 800 would be fine to sync with..
Glory be! I have recieved good tidings today by virtue of a missed voice mail. A return call form the eWiz RMA dept called to confirm that the malfunction which I reported in my RMA request is actually repeatable and unexplainable. This is good news to me, hopefully it means the rest of my gear is in working order and it wasn't my ineptitude that caused the malfunction. YAY!!
As we speak a new shining wonder of circuits, capacitors and resistors is hurtling through the nether towards me. Actually it won't ship till to tomorrow but I couldn't resist the mental image of my new board on it's winged way. According to the wiz, it should be in my clutches by Monday.
With the level of anticipation I'm mounting, this thing better summon demons to do my bidding.
At the very least it better put on a mean game of BF2142 which has been patiently waiting beside my monitor for 3 weeks now. Good luck guys and congrats to Officer Martinez on his stellar air OC.
^^ very nice. I hope the carrier has a tail wind the whole way. :D
ok - cool. I have ddr2-1000 so I should have some headroom to leave it sync'd. so far so good.. my machine locked up here last time.. so I think something was for sure amiss with that other board.
srry dbl post.. but this is so messed up.. this board is doing the same damn thing.. loud hissing noise coming from the PWM area.. I have confirmed it's not my PSU.. but this is just so not cool.. my wife can hear it from the couch... I'm really kind of pissed now.. I have spent way too much of my time re-building this machine and I just can't keep doing this... calling Abit tomorrow.. of course they'll say "rma the board".. gah. I am at a loss for words right now..
Maybe I am going crazy? no one else's board are making any noise? if I set the vcore to anything over 1.4 or put the machine under load it starts "hissing".
Again? Damn! Before you even got started this time, on your new build, did you rip off the Silent OTES pipes in lieu of your other new and improved cooling measures?
No - I have the stock stuff on.. it's got to be something about my psu's power feed?? I am not sure.. OfficeM, you have the same psu, can you hear something coming from the pwm area? default vs overvolted on the vcore?. . . also, did you hook both of the 4pin power plugs to the cpu power area, to make one 8pin power plug? I am thinking about trying it with just the one which says 12v on it.. rather than using both, which is what you're supposed to do.. but something is not right here.. anyways, getting two of these boards with issues in a row is just un-canny.. I am for sure calling abit tech support today.. there's got to be something I can do.. I let it run orthos all night, it seemed to be quiter this am, then tried 1.4v again.. hissssssssss... grrr
edit: it sounds like a shower through the bathroom door. I found that if I touch the top of the chip that says "PULSE" on it, it quiets the sound.. I think I can wedge something between that chip top and the Tuniq's bracket, which is right overhead. I'll try that tonight. In other news.. Abit is in Fremont. lol. I'm driving by there today.. I think I might pay them a visit in person.. lol. "WTF guys??!?!??" lol
edit #2: tried to get abit on the phone.. waited for 30mins twice and had my call dropped while on the road.. suck! pretty bad, abit.
edit #3: this is why I like hanging out at xtremesystems, sometimes.. they have these electronics gurus who read and post there, which is very handy for issues like this... here's some good feedback I got on the PWM sound issue:
You need both connected!
For the sound thing, try pushing parts with your finger and listen for pitch changes or other.
The pulse chip is actually 5 inductors in an unusual sandwich chip package... could be that the metal resonates against the chip sandwich (if loose). Also check applying some force on the metal parts of your case, psu and such.
Tip: I've made a stethoscope like instrument to help pinpoint noises in all sorts of devices. you can buy one or make one really easily. i used one of those tube type headphones they used in airplanes just by sticking a hard non conductive plastic probe pin in the end of the tube.
furthermore, it would appear that this sound I am hearing is a very typical sound for a PWM to make.. and lucky me with dog ears, I can hear lots of things others find inaudible.. dandy. so I might be SOL here.. I need to make a work bench so I can run the machine while I have easy access to the PWM pulse chip so I can apply pressure on different parts of it, trying to see which might be loose and/or then find a way to dampen the noise..
When I called Abit tech support, I waited over 2 hours to talk to a person that barery spoke engrish. Don't look for a lot of help from the over phone tech support guys. I asked this yahoo to kick me up to tier 2 and he immediately went into his 'RMA" mantra. I finally just had to hang up.
yeah - I sent an email to them... I don't expect real help, but just trying all the avenues.. after all, it's their board. lol. I thought someone there might be concerned about such issues. :p
Of course, you address the issue properly and go through all the proper channels.
Took me 5 days to get an email reply from Abit online tech support. Just to prepare you. Sounds like you have a patience threshold pretty close to mine.
as in "almost none".... ie, I suffer often while "waiting" for things.. lol.
I found some hard rubber stoppers which go into the ends of fiber optic network (Gbic) modules which I think will make excellent wedges for trying to dampen this noise.. I have lots of them also so I can experiment with different cuts, shapes, and sizes... it might also turn out that I have to put some under my mobo right near the PWM area, to dampen the whole area.. I hope not, but I have been reading lots of random stuff about pwm vibrations and hitting resonance, etc.. the mobo tray and mobo are very prone to vibrate in a way which can cause a resonance wave..so who knows.. I'm going to see if my wife can hear this thing tonight.. maybe it is only me. lol.
Wow.. Sounds like my initial little issues pale in comparison to yours.. But yeah, as for my PSU, I did use both 4 pins to make 1 large eight "pin" ..The Enermax is a really good PSU and now that you have found your issue, what are you going to do..?
man... I spent all night trying to silence this pwm.. no dice.. I am not sure if I got another "bad" (marginal?) board or if it's just some combination of my cpu and psu which is causing this.. I ran the board while out of the case on the tray, tried pusing on the pwm pulse chip with con-conductive probes.. nothing would work... I pulled the whole board apart twice... no change what-so-ever... so I either have to live with this, go with a different board I guess.. not sure.. I just got back into the LOTRO closed beta, so I need to get my gaming rig back up to snuff.. I guess I will try this board and if I can't stand the noise I'll get another 680i board when it comes out.. maybe the gigabyte?? hrm.. the jury is out on this for now.. orthosing now @ 3.5ghz... my PWM is over 80c now.. freaking hot.. whew.
everytime I do anything, launch any program or do anything, the noise squeels and changes pitch.. I am so getting rid of this board.. no way am I going to tollerate this long term.. crazy.. I am going nutz to know if this is soemthing about my system components which is causing this?? :(
dont you have secondary components to test the board more throughly
the board I have hasnt given me any of the problems posted in this thread..
not even a hissing thing you described..
Man thats aweful. I'm very sorry to hear about this issue. Do you think if you RMA'd it again, that the 3rd time would be the charm? Staying on the phone for a while talking to someone OTHER THAN the entry level support seems something I personally would do. You'll get no where fast with entry level support. Maybe fire off an email to their sales department. I know it is VERY frustrating to say the least, when you have to RMA one item over and over.. But you're right.. Frustration has definately set it and maybe it's time to consider a different avenue. BTW, when is DFI coming out with their 680i board? I read something on the Inquirer but I don't put alot of stock into anything they print.
wow was I in a bad mood last night.. man. just lots of things going on right now.. I was disparing. heh..
So some peeps on XS think it's my psu... which I have a feeling could be right.. but I just sold my old 24pin EPS psu so I am SOL on one to try unless I buy something else.. I should have held onto that one a little longer.. gah! I'm going to contact enermax... because the problem followed with the next mobo.. it's got to be something I have.. the psu is the obvious next link in the chain..I'm hoping enermax will cross-ship. fingers X'd!
I have a spare, very low watt though (generic 400watt), 24pin power supply that came with a case/computer that I built for a friend. It probably wouldn't run your entire system, but you could probably strip your rig down and power up with it to at least test for the pwm noise. If you would like me to send it to you, I will. Just pm me your shipping info and I'll send it out tomorrow. All I would ask in return is send it back when you are done.
What do you think?
Shawn
Rev, if you think it might have anything to do with your PSU, post a question over on jonnyGURU.com those guys, especially Jonny are very sharp. As far as I'm concerned Jonny does the best PSU reviews out there. He is one of the few people that does active load testing and he KNOWS his way around a power supply. If it's something PSU related and can be fixed, I'm sure he can help.
JonnyGURU.com
AHHHHHH! I think we got it.. I got the old model DXX without the dedicated 8pin EPS power plug... the one I have only has 4+4 pin.. the guy at enermax is going to ship me the new model for free.. well, I have to send him mine.. but we're both in cali, so should only be a couple days.. sweet! he thinks the psu should quiet things up.. their dedicated 8pin plug has new circuitry the 4+4 pin does not. I bet that's it.
Thats good news... right? If I was you I still might post something over there. Everybody is really nice and it might give you some peace of mind while you....... dare i say it?????
WAIT!! ARGGGHH!!!!
heh.. ok, maybe later.. I have too many threads running right now.. :eek: ;)
